Itchin' for a hitchin' for our 2013
Would love to hear if anyone had the OE hitch installed or know of a third party hitch company that makes a direct bolt on.
This would be used for very light utility trailers, bike racks or hitch-hauls.
Regards, Jim
Obviously, things like cargo tray don't really matter but anything like "block heaters (for Canadian climate), TPMS for steel rims etc would be agreat idea to have included on the sales contract to make sure you get the best warranty on the items. I always try and anticipate what I will need prior to buying my Acura's for this purpose.
Just my 2 cents.... (which in the US would be worth one and a half cent)
I had the OEM hitch installed about 3 weeks ago when I bought my RDX for the same reasons you mention in your post. It looks good. Cost quoted was $687 installed, but I bundled it in with several other things (splash guards, mats and cargo cover) for $850. Not sure how they broke that all out as to what the hitch cost by itself.
I'm really hoping to save a few bucks and install it myself. I guess I'll wait a bit for a real hidden style hitch or just buy one from the dealer.
Good point about the warranty though.
Pics?
Pics?
Can anybody take a pic of the OEM hitch if they've had it installed?
2013 RDX OEM Hitch Installation
I just completed the installation of the OEM Hitch on my 2013 RDX. $278 + shipping from Bernardi Acura parts. The install is relatively simple as long as you are comfortable with removing the rear bumper cover. No drilling is required - the hitch bolts in to two threaded holes in the frame and four bolts which are inserted from within the spare tire compartment. A small cutout on the underside of the bumper cover is required and nicely done with a lubricated hacksaw blade.
Pics of OEM hitch
Sorry about the picture quality. It was late and getting dark ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
http://www.flickr.com/photos/31518039@N05/7255516326/
http://www.flickr.com/photos/31518039@N05/7255516874/
The following 2 users liked this post by espo711:
juice13 (05-23-2012),
Rocketsfan (05-23-2012)
Did you install the hitch wiring harness? I'm not sure I would need this for the very limited towing I would do. More precisely, the very limited towing the RDX can do.
http://acura.bernardiparts.com/Image...s_BII13528.pdf
U-haul says the 2012 hitch will fit, when I asked for a 2013 hitch. I cannot confirm. CURT makes a decent looking round tube model.
http://www.etrailer.com/Trailer-Hitc...eid=2012306817
Again, I cannot confirm.
StayAtHomeDad
I also doubt it would fit
Understood. Looking at the 2012 and 2013 OE hitch instructions, they look quite similar. Then again, these are install instructions, not CAD drawings. I also don't assume that CURT would use all three mount holes, maybe only two. Better to wait until CURT and other aftermarket companies can test and verify. I don't want to create a diversion here any more than I already have.
There are indeed 3 attachment points (on each side). One is threaded to the frame, the other two are thru-bolted from above in the spare tire compartment. The Acura hitch tucks up nicely under the bumper (hence bumper removal is required). Based on past experience, I doubt the Curt or other aftermarket hitches would be as "hidden", but that's just my guess. The downside to the Acura hitch is that it is Class I (1-1/4") only, which is appropriate since the vehicle is not designed to tow more than 1500 lbs, but a pain since many bike racks (including mine) have a 2" fitting.
By the way, the Acura part numbers for the 2012 and 2013 hitches are different. I would be suspicious of the info you received from U-Haul. Etrailer and another online retailer both told me that had not examined the 2013 yet.
StayAtHomeDad
And just so you don't go buying something thinking that you can return it later, once the hitch has been installed/mounted, it cannot be returned....they can probably argue that you did, just because.
Totally agree. It is nicely hidden, but I have a small cargo rack with the 2" fitting I want to use and don't prefer the Class 1 adapter arrangement. I suppose the Class I is properly suitable to the vehicle, anyhow.
Stupid question here as I've never owned a bike rack or had the need to transport a bike, but : I'll probably be transporting a bike around to ride should I get the new RDX. Is it possible to fit a men's mountain bike in the cargo area of the RDX with the front tire removed (and with the rear seats folded down, of course)?
Rocketsfan...although I never tried myself, I'd be very surprised if it would not fit. When the seats are down, the cargo area is quite large....When the seats are not down, the cargo area is smaller than my Rav4 but the seats of the RDX are static in that they don't slide forward and backward as they did on the RAV4. The static rear seat configuration is designed to give maximum leg room for the rear passengers at the expense of the cargo area....but when down, that whole area opens up quite nicely!
StayAtHomeDad
Scratched the hitch itch
Ordered the OE hitch from Bernardi. Hope to install it this weekend.
Now to find a bike rack and a hitch-haul that fit the 1.25" receiver.
Looks great and two trips with the Yakima Double Down (specific to the 1.25 receiver) without issues.
Next item is a hitch haul:
http://www.discountramps.com/receive...FQ8KKgodIVNGVw
Looks like etrailer has a couple hitches for the 2013; however, they may be the same that they sell for the 2012 (instructions are dated 2010).
http://www.etrailer.com/hitch-2013_Acura_RDX.htm
Also, I cannot find a wiring kit for the 2013.
Anyone tried one of these hitches?
Review from etrailer on hitch installation on a 2013 - not very encouraging:
Rated good since etrailer did a great job expediting my order and getting it to me quickly. And, the hitch itself is heavy duty and good quality. However, installation was very difficult. This hitch must not have been tested on a 2013 Acura RDX. To say that the rear fascia may need to be slightly pulled down is a gross understatement (at least for the 2013 RDX). The holes would not line up by about 3/4 of an inch. The hitch was pushed directly against the fascia support brackets, which do not give easily. It took one person pulling very hard on the fascia while another person struggled to push the hitch in place so the holes would line up. Then, while struggling to do that, you have to hold the weight of the hitch and thread the screws. We eventually enlisted a third person to help. Would not rate this installation difficulty a 3. I eventually succeeded in installing the hitch, but a better design would have made it much easier.
According to the reviews I may have to grind down a tab to fit into the Class 1 hitch. I'll update later.
Seeing how low the hitch is I wonder if I'll need one with a step up:
http://www.etrailer.com/Hitch-Cargo-...Tite/6500.html
Masterbuilt 30110208 The Original HITCH-HAUL Cargo Carrier with 2" and 1.25" Receiver Bars
Just picked up a 1 1/4 receiver hitch haul at Walmart. Got good reviews on Amazon (and the best review mentioned the deep discounted price at Walmart).
I'll keep the thread alive with impressions when it comes in.
I had a Curt 2" trailer hitch installed by the dealer. The money that I saved over the OEM version is incredible. The OEM hitch is only a class I which eliminates a lot of options. I had the class III installed. Dealer did it for free (new purchase.) I bought it so that I could attach a cargo carrier so I could carry more when we travel. They did a great job on the hitch but I think they forgot the light package! Getting that straightened out as I write.
StayAtHomeDad
Indeed, towing is one metric. But hitch class will also dictate "tongue weight" which is the weight you can "hang" on the hitch. In my case, I want to use a cargo carrier. Class I limits the weight it can handle to something like 200lbs.I need more. Class III will support 300-500 lbs. I hope that's clear.
As far as I know, your hitch class determines the amount you can pull, tongue weight the weight on the trailer coupler. So, Class I is typically rated to tow a trailer up to 2000 lbs and 200lbs of load weight. Class II 3500/350 and Class III 8000/6\800. When I bought my carrier, it was rated for 500 lbs tongue weight and it's a class III hitch si I guess I can attach something up to 8k lbs (never happen for me.)
I got all of this info from etrailer. they have a massive amount of info.
wrestrepo (03-14-2013)
