Annoying door warning beep...
On my '16 RDX, there is a beeping noise EVERY time I open the drivers door, whether from inside the vehicle or outside. None of the other doors turn on this beep where their doors are opened. I've looked in the manual, but can't find anything about this warning. Is there a way to disable it short of just cutting the wire.
Nan (11-07-2023)
I also have a 2016 RDX, but I don't think I have heard the type of beep you are describing. Perhaps you could provide a better description?
Is the beep coming from inside the vehicle, or is it from outside the vehicle (similar to the beep that occurs when you press the lock button on the door handle)
Is it a single beep, or is it two or more beeps?
Does it only occur when you open a locked door (i.e. when you touch the backside of the handle to enter) or does it also beep as well as when the door is already unlocked?
Carbon Bronze Pearl 2008
With that said, the RDX does have a proximity sensor and will make a bunch of rapid multiple beeps if you exit the car with the key fob in your pocket, close the door, and the car is still running. Maybe that’s what you’re talking about? If so, it’s normal.
I too have a 2016 RDX. The vehicle does make lots of beeps regarding to what you’re doing. But, as RDX-Rick asks, can you provide a better description?
On the RDX you can hear a clunk when the car immediately unlocks itself after you lock it if the driver's key is still inside.
As to the problem at hand, even with all the beeps and warnings on our Advance model, we hear no beeps. Maybe try another setting on the steering wheel, the Info button, way down in the menus.
There is a small beep when you unlock the car (central locking and unlocking) but that is present regardless of opening the driver or passenger door / or remote control. Is that what you are referring to or is it something else.
But this doesn't happen if the car is already unlocked and you open the driver door.
There is a constant chime in other makes / models such as Mercedes when you open the driver door every single time (regardless of if it's locked or unlocked), but that is by design. I haven't noticed it in my RDX.
Beep beep beep
The beeping noice (chime?) is continuous once the driver's door is opened, either from an locked or unlocked state. It doesn't stop until the door is fully closed. As I already stated, none of the other doors make this sound. The noise seems to be coming from behind the driver's instrument panel which probably doesn't mean anything other than that's where the noise is generated.
The open door beeps whether the key is in my pocket or in the house. I guess I'll have to take a trip down to my local Acura dealer and see if this is normal. However, judging from some of the replies above, other RDX's don't make this sound when the door is opened.
Nan (11-07-2023)
The beep which the OP is talking about happens when the ignition is in accessory mode and driver door is open (regardless of the position of the key). This chime is continuous and will stop only when the driver door is closed. You can check it on your RDX right now if you can.
p.s. I don't find this chime annoying but very well understand if it bothers kids / babies sleeping inside the car.
Nan (11-07-2023)
This chime / beep is so unobtrusive that only the OP has even noticed it to be annoying.so far. Just shut the driver door and save the visit to your dealer. What else can I say.?
OK, stupid me! I finally discovered what is causing the BEEP (and it is loud). And should be. From the REAL owner's manual which I had to request after buying the vehicle new in '15. Page 15 in the manual.
"Why does the beeper sound when I open the door?"
Answer, The beeper sounds when:
The exterior lights are left on OR
The power mode is in ACCESSORY.
So, sometime in the last few months or perhaps the last year, I inadvertently turned the headlight switch from auto to on and have been driving that way ever since the beeping started. Once again, the beeping only occured with the driver's door open so no beeping while driving. In this condition back in the ole days, this would guaranted a dead battery. However, Accura automatically turns the headlights off after a few minutes when the engine is off.
I'm writing it all off to "senioritis". Thanks for all the inputs...
Stay Out Of the Left Lane
Received 1,236 Likes
LOL - I was just going to "chime" in and say that our 2016 RDX Advance doesn't seem to make the same noise as being described unless OP has the headlights set to On. Glad you got it sorted out.
I don't think I've own a vehicle since '99 that didn't have "auto" headlights" and that include a Pontiac, Durango, Jeep, VW, Mini, Ford Flex, Range Rover, and the Acura. YES, I admit I trade in too often. AFAIK, the Acura looks the same in the day with the driving iighs on as it does at night on low beam.
