2013 Acura RDX Technical Service Bulletins
Forum Contributor
Received 1,391 Likes
2013 Acura RDX Technical Service Bulletins:
TSB 12-009 - 2013 RDX: TQI and New Model Service Information
Applies To: 2013 RDX - ALL
http://www.urvi.net/forumfiles/SB/B12-009.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-009.PDF
TSB 12-010 - 2013 RDX: TQI of the Navigation System
Applies To: 2013 RDX With Navigation - ALL
http://www.urvi.net/forumfiles/SB/B12-010.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-010.PDF
TSB 12-008 - 2013 Acura Paint Codes
Applies To: 2013 Models - ALL
http://www.urvi.net/forumfiles/SB/B12-008.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-008.PDF
TSB 12-025 - Rear Seat Doesn't Fold Down
http://www.urvi.net/forumfiles/SB/B12-025.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-025.PDF
TSB 12-026 - Front Floor Undercover Rattles at Highway Speeds
Applies To: 2013 RDX - 2WD - From VIN 5J8TB3H...L000001 thru 5J8TB3H...L006582
2013 RDX - 4WD - From VIN 5J8TB4H...L000001 thru 5J8TB4H...L009268
http://www.urvi.net/forumfiles/SB/B12-026.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-026.PDF
TSB 12-034 - HFL (HFT) System Issues
Applies To: 2013 RDX - 2WD - From VIN 5J8TB3H3...000001 thru 5J8TB3H3...006160
2013 RDX - 2WD with Technology Package - From VIN 5J8TB3H5...000001 thru 5J8TB3H5...006402
2013 RDX - AWD - From VIN 5J8TB4H3...000001 thru 5J8TB4H3...008804
2013 RDX - AWD with Technology Package - From VIN 5J8TB4H5...000001 thru 5J8TB4H5...009085
http://www.urvi.net/forumfiles/SB/B12-034.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B12-034.PDF
TSB 13-004 - Siri Eyes Free HFL Software Update
Applies To: 2013 RDX - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B13-004.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-004.PDF
TSB 13-015 - MIL Comes On With DTC P3400 and/or P3497
Applies To: 2013 RDX - 2WD - From VIN 5J8TB3...DL000001 to 5J8TB3...DL006466
2013 RDX - 4WD - From VIN 5J8TB4...DL000001 to 5J8TB4...DL009205
http://www.urvi.net/forumfiles/SB/B13-015.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-015.PDF
TSB 13-019 - Safety Recall: 2013 RDX Shift Interlock Stopper
http://www.urvi.net/forumfiles/SB/B13-019.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-019.PDF
TSB 13-020 - 2013 RDX: Front Brakes Squeal
Applies To: 2013 RDX - 2WD - From VIN 5J8TB3H..DL000001 thru 5J8TB3H..DL016429
2013 RDX - 4WD – From VIN 5J8TB4H..DL000001 thru 5J8TB4H..DL020459
http://www.urvi.net/forumfiles/SB/B13-020.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-020.PDF
TSB 13-029 - Front Doors Do Not Unlock or Open in Freezing Weather
http://www.urvi.net/forumfiles/SB/B13-029.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-029.PDF
TSB 13-030 - HFL (HFT) System Issues
2014 RDX - 2WD - From VIN 5J8TB3...EL000001 thru 5J8TB3...EL003250
2014 RDX - AWD - From VIN 5J8TB4...EL000001 thru 5J8TB4...EL006660
http://www.urvi.net/forumfiles/SB/B13-030.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-030.PDF
TSB 13-040 - Tailgate Spoiler Seal Comes Off
2014 RDX - 2WD - From VIN 5J8TB3..EL000001 thru 5J8TB3..EL005747
2014 RDX - AWD - From VIN 5J8TB4..EL000001 thru 5J8TB4..EL008303
http://www.urvi.net/forumfiles/SB/B13-040.PDF
http://techinfo.honda.com/rjanisis/pubs/SB/B13-040.PDF
TSB 14-001 - Vibration at Highway Speeds During VCM Operation
Applies To: 2013 RDX - AWD - ALL
2014 RDX - AWD - From VIN 5J8TB4...EL000001 thru 5J8TB4...EL019936
http://www.urvi.net/forumfiles/SB/B14-001.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-001.PDF
TSB 14-006 - MIL Comes On With DTC P0455 and/or P0456
Applies To: 2012 RDX - ALL - ALL
2013 RDX - 2WD - From VIN 5J8TB3...DL000001 - 5J8TB3...DL008083
2013 RDX - AWD - From VIN 5J8TB4...DL000001 - 5J8TB4...DL004910
http://www.urvi.net/forumfiles/SB/B14-006.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-006.PDF
TSB 14-027 - Moonroof Will Not Auto-Close or Reverses Direction
Applies To: 2013-14 RDX - ALL - ALL
2015 RDX - 2WD - From VIN 5J8TB3...FL000001 thru 5J8TB3...FL006607
2015 RDX - AWD - From VIN 5J8TB4...FL000001 thru 5J8TB4...FL010639
http://www.urvi.net/forumfiles/SB/B14-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-027.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2007-15 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-048.PDF
TSB 14-053 - TIGHTEN FUEL CAP Message On or DTC P0455 and/or P0456 is Set
2015 RDX - ALL 2WD - From VIN 5J8TB3...FL000001 thru 5J8TB3...FL010016
2015 RDX - ALL AWD - From VIN 5J8TB4...FL000001 thru 5J8TB4...FL017148
http://www.urvi.net/forumfiles/SB/B14-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B14-053.PDF
TSB 15-012 - AWD Light Comes On and Sets DTC C1858-73
Applies To: 2013-14 RDX - ALL with AWD - ALL with AWD
http://www.urvi.net/forumfiles/SB/B15-012.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-012.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2013–16 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-047 - Noncompliance Recall: RDX Emission Label
Applies To: 2013 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-047.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-047.PDF
TSB 15-051 - HFL Poor Sound Quality or Static
http://www.urvi.net/forumfiles/SB/B15-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-051.PDF
TSB 16-002 - Front Brake Noise and/or Front Brake Judder
This bulletin is replaced by S/B 17-049, Front Brake Noise and/or Front Brake Judder (2013–18 RDX).
Applies To: 2013-15 RDX - ALL - ALL
2016 RDX - 2WD - From VIN 5J8TB3...GL000001 thru 5J8TB3...GL012358
2016 RDX - AWD - From VIN 5J8TB4...GL000001 thru 5J8TB4...GL019272
http://www.urvi.net/forumfiles/SB/B16-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-002.PDF
TSB 16-010 - Safety Recall: Takata Driver’s Airbag Inflator
Applies To: 2007-16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-010.PDF
TSB 16-043 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch
Applies To: 2013-17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-043.PDF
TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather
Applies To: 2013-16 RDX - ALL - ALL
2017 RDX - All 2WD - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL009835
2017 RDX - All 4WD - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL015307
http://www.urvi.net/forumfiles/SB/B16-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-059.PDF
TSB 17-017 - 2013-17 RDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2013–17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-017.PDF
TSB 17-018 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B17-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-018.PDF
TSB 17-049 - Brake Judder (2013–18 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-020 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2013-14 ILX Hybrid and Other Listed Years and Models (Expires February 28, 2026)
Applies To: 2007-15 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-020.PDF
TSB 18-028 - Warranty Extension: Customer Support Program For Front Passenger's Airbag Inflator for 2013-15 ILX and 2013-15 RDX (Expires June 30, 2030)
Applies To: 2013-15 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-028.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-028.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2007-18 RDX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF
TSB 20-014 - Front Rocker Arm Oil Control Valve Leaks
http://www.urvi.net/forumfiles/SB/B20-014.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-014.PDF
