Usb Flash Drive Folders
I loaded new folders onto my USB flash drive to play in my car and now the navi is not seeing the new folders. Is there a reason why? Should I try to refresh the folder?
Not sure...I use a USB stick in my RDX and never had any problem seeing them. Now you will find many annoyance with the USB and its folder functionality but I will not ruin your disappointment....You can see my gripe in the problem section.
^^ There can be some advantages to put them in folders but also some drawbacks. I have my artists in Alphabetical order (an A folder for artist with last name A, a B folder for the artists who's last name start with B and etc)
I think the car has a memory setting personally where it remembers the directories of a certain usb device. Therefor I moved files onto it and it did not see the new files. I am trying to recopy everything again as a whole. I will let you know how it goes.
I put all my music (in folders and subfolders) on USB stick. I only had an issue once where the stereo told my that the stick was unrecognisable. Turns out this particular USB had a built in security software that was messing with the car's stereo. Once I reformatted the stick everything worked fine.
Standard FAT format is what I used. Though I have had a hard time getting it to recognize some flash drives. Large capacity, USB 3.0, and the small monolithic drives seem to be problematic.
Registered RDX Member
Search Folders?
I use folders too. Is there any way to search?? I've looked and don't think there is, I'm pretty sure it's just scroll and scroll.....
Had to ask...
Had to ask...
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
HeloDown
09-08-2015 06:51 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
