Usb Flash Drive Folders
I loaded new folders onto my USB flash drive to play in my car and now the navi is not seeing the new folders. Is there a reason why? Should I try to refresh the folder?
Bump anyone know why I cannot see the new folders in my car, but can see them on my comp.
Not sure...I use a USB stick in my RDX and never had any problem seeing them. Now you will find many annoyance with the USB and its folder functionality but I will not ruin your disappointment....You can see my gripe in the problem section.
Dont put them in folders
^^ There can be some advantages to put them in folders but also some drawbacks. I have my artists in Alphabetical order (an A folder for artist with last name A, a B folder for the artists who's last name start with B and etc)
I think the car has a memory setting personally where it remembers the directories of a certain usb device. Therefor I moved files onto it and it did not see the new files. I am trying to recopy everything again as a whole. I will let you know how it goes.
I put all my music (in folders and subfolders) on USB stick. I only had an issue once where the stereo told my that the stick was unrecognisable. Turns out this particular USB had a built in security software that was messing with the car's stereo. Once I reformatted the stick everything worked fine.
What formatting did you use to make it recognize the USB? I feel like I've tried everything
Originally Posted by HondaJockey
(Post 16387507)
Search Folders?
I use folders too. Is there any way to search?? I've looked and don't think there is, I'm pretty sure it's just scroll and scroll.....
Had to ask... |
