Notices
Spark plugs replaced at 96,000 miles
Old 11-17-2018, 07:48 PM
Registered Member
Liked 6 Times in 4 Posts
The sparks plugs look quite worn, but there is no sign of oil-fouled plugs that plagued earlier VCM engines.
Base2014RDX is offline
The following users liked this post: Base2014RDX
Comfy (11-28-2018)
Old 11-17-2018, 08:37 PM
Registered Member
Brown13's Avatar
Liked 33 Times in 28 Posts
Don't look worn to Me.Center electrodes are that small when new and lateral electrode has no metal loss.
Brown13 is online now
Old 11-17-2018, 09:47 PM
Registered Member
Tech's Avatar
Liked 65 Times in 49 Posts
Are you the original owner and if so, are these the original plugs out of your 2014?
How did they come out? Any binding, etc?
Tech is offline
Old 11-22-2018, 01:29 PM
Registered Member
Yes I am the original owner and those are the original plugs.
My hands are not strong and I used a small ratchet for the job, so I found them quite tough to remove and almost reached out for my breaker bar.
The following 2 users liked this post by Base2014RDX:
Comfy (11-28-2018), Tech (11-22-2018)
Old 11-22-2018, 04:11 PM
Registered Member
Tech's Avatar
Understandable when they have been in that long.
I can see needing extra force to break them loose, but once loose, did they unscrew easily? Plugs for some time now have lasted big miles and that worries me when it comes to removing them. I do not see any aluminum deposits in the threads which is good.
Tech is offline
Old 11-22-2018, 05:05 PM
Registered Member
Yes, they came off very quickly after that. I used a magnetic spark plug wrench so the job was easy. Interestingly, the most difficult part for me was removing the harnesses from coil packs.
SandwichViking (11-22-2018), Tech (11-22-2018)
Old 03-08-2019, 06:47 AM
Registered Member
Liked 12 Times in 12 Posts
Valve adjustment is also recommended around this time, i also believe timing belt and water pump
auskip07 is offline
Old 03-08-2019, 11:35 PM
Registered Member
Liked 5 Times in 5 Posts
The interval for this engine, before the MID set codes, was 105,000 miles. Timing belt, drive belt(s), spark plugs, valve adjustment. The coolant is often replaced at this time as well, even though
120k is what used to be called for. You have to drain a lot of coolant to do the timing belt properly (replacing the water pump) The timing belt tensioner should also be replaced. Some dealers include
that cost and some low ball and call you to say it needs replacing while you car is apart. Just ask when price shopping.
egads is offline
Old 03-15-2019, 02:06 PM
Registered Member
Liked 1 Time in 1 Post
It looks not bad either to me! The iridium plug can last 120k miles. Recently I changed the sparkplugs in my 2011 Outback with 90k miles on it. It look good also. My 06 Sienna has 175k miles on it now with original sparkplugs. I did not changed them since the three on the back are hard to work on. These iridium sparkplugs last long time!
hongthan is offline
russianDude
First Generation RDX (2007-2012)
14
10-23-2014 09:24 PM
99acuracl
1G CL Problems & Fixes
06-14-2008 10:35 PM
gregshin
Second Generation CL Discussion (2000-2003)
11-17-2003 10:52 AM
Quick Reply: Spark plugs replaced at 96,000 miles
