side view mirrors adjusting on their own - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 01-11-2018, 11:00 PM   #1
Registered Member
during backing up or after putting the car in reverse the auto mirror adjustment causes the mirrors to go up or down to the point where the mirror starts popping from exceeding the adjustment range. This happens to which ever mirror is set to be auto adjusted. do i have a bad mirror switch? car is out of warranty and i would rather not pay someone to fix this.
auskip07 is offline   Reply With Quote
Old 01-12-2018, 05:19 AM   #2
mrgold35
mrgold35's Avatar
Most of the time the fix is to pop out the both mirrors and clean and re-grease. YouTube has a few videos (mostly MDXs) on how to remove the mirror and change out the mirror actuator.
mrgold35 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrgold35 For This Useful Post:
Brown13 (01-12-2018), justnspace (01-12-2018)
Old 01-12-2018, 02:01 PM   #3
Registered Member
Quote:
I dont think it needs greasing. what ever is controlling the mirror is causing the issue. the lack of grease wont cause the mirror to fight the mirror switch when im driving down the road.
Old 01-12-2018, 03:29 PM   #4
Registered Member
quantum7's Avatar
http://techinfo.honda.com/Rjanisis/pubs/SN/B090200.PDF
Old TSB for the 3G TL, but I do recall that greasing the actuator solves at least this problem
Here is the greasing link that apparently helped at least a few.
https://acurazine.com/forums/3g-tl-p...-045-a-832020/
quantum7 is offline   Reply With Quote
Old 01-12-2018, 06:50 PM   #5
Registered Member
RDX10's Avatar
Guys I think he is complaining about the mirrors moving on their own more than the popping. What you should do is move your mirror selector switch (the one you slide to the right or left to select which mirror to adjust) to the center position and it should stop making the mirrors move when you reserve.
RDX10 is offline   Reply With Quote
The Following User Says Thank You to RDX10 For This Useful Post:
auskip07 (01-12-2018)
Old 01-12-2018, 08:31 PM   #6
Registered Member
ok i was curious what would cause it to go crazy i might try another door switch and see if that works.
Old 01-13-2018, 12:40 AM   #7
2014 RDX AWD Tech
Comfy's Avatar
Do you see the mirror vibrating during those moments you described? I had a similar issue and the mirrors were replaced under warranty.
Comfy is offline   Reply With Quote
Old 01-13-2018, 09:39 AM   #8
Registered Member
Mirrors are smoothe as silk and no weird noises but while driving it's almost as if someone is pushing on my adjustment switch. And causing the mirrors to tilt upward. Then a few times the mirror set to tilt down on reverse will keep tilting down until it starts popping. This happened when I picked the car up from the dealership and I had no clue what was happening and then shortly after my warranty expired
Thread Thread Starter Forum Replies Last Post
Side mirrors stopped adjusting today akplaya92 3G TL Problems & Fixes 15 07-18-2013 11:35 PM
adjusting coilover question, adjusting one side raise the other?? ed_423 2G TSX Tires, Wheels & Suspension 7 08-02-2012 01:33 PM
Side markers on the driver and passengers side rear view mirrors BigJoe04TSX 1G TSX Performance Parts & Modifications 2 03-12-2007 11:58 PM
Study: Womens view of their own asses NighthawkBlue Dating & Relationships 15 03-02-2006 12:31 PM
Constantly adjusting side view miorror Nukeman Third Generation TL (2004-2008) 6 06-15-2004 09:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
