Service question
Service question
I have a 2013 RDX AWD with about 21,000 miles. I recently went to the dealership for an oil change and tire rotation. While I was waiting, the service rep came out and told me that I need to do a "rear differential service" and "brake flush". I didn't know anything about these services so I told the rep that I will come back after I do some research. I have a feeling they will cost me hundreds of dollars so want to make sure they are necessary. Any thoughts would be appreciated. Thanks.
Maintenance info says replace brake fluid every 3 years.Your vehicle has to be close to being out of warranty,so time to do it Yourself.If Your are handy and have ever bled brakes,then replacing brake fluid is a snap.Rear differential ,check out RDX DIY FAQ.If not, ask Dealer "How Much?".Any servicer can flush brake fluid.Some have had Honda Dealers offer the same service for less.Your reseach has begun.
balancesheet (04-03-2017)
The rear diff fluid change (subsymbol 6 on the Maintenance Minder) is going to pop up on your display soon, so you can do it now, or wait and do it soon. You can tell the dealer you will wait until it pops up on your MM. The brake fluid change is not included in any MM messages.
balancesheet (04-04-2017)
I agree with justnspace.. but not because he may otherwise pinch my bum with those evil pincers.....buy 2 litres of the DPSF fluid for the differential and have your local garage put it in...I also think doing the brake fluid is a reasonable idea at this point but its certainly not a big priority, esp. considering your low mileage. I personally would do that as well as change the coolant every 40-50,000 miles.
I found an import service place in the DFW area that specializes in Hondas/Acuras, with most of the techs coming from Honda dealerships. No BS but terrible coffee (versus BS and great coffee at the dealer). My son found a BMW specialist that saved him a ton of $$, but now he has our old '13 RDX and is seeking a Honda/Acura shop. Yes, research, lots of it.
This requirement to flush brake fluid is pretty much a scam. I have never changed brake fluid on any of my vehicles and have had several for over 200,000 km.
I religiously service the pads and rotors but the fluid is basically good forever unless you are racing or operating in some very extreme climate.
Yeah, I know it is hygroscopic. Our TL is 7 years old now (120,000 km) and on the original brake fluid which is still a nice pale yellow colour.
Change oil and ATF frequently, yes for sure, but not brake fluid. And we are still on the original coolant also.
Car runs perfect and does not burn a drop of oil, trans shifts perfectly also.
Car runs all day at 120 - 130 Klicks (75 mph). No issues.
andy
Drain and Fill =/= "flush"
Drain and Fill is the approved method, do NOT flush. Flushing is defined by using a machine to forcibly push out the fluid from the trans case a la Jiffy Lubes and the like.
i recently did the tranny drain/refill...the fluid was noticeably darker coming out than the new fluid, so I did a 2nd drain and re-fill a week later and can now sleep well. Also drained/refilled the transfer case and the gear oil came out almost black..the new oil is a clear yellowish color....the oil and tranny fluid was supposedly changed 28000 miles ago by the dealer....ya right....
