Notices
Parking Brake Adjustment
Old 08-28-2014, 06:56 PM
Registered Member
Question Parking Brake Adjustment
Does anyone know how to adjust the parking brake? The parking brake on our RDX barely does anything. The dealership says nothing is wrong, but we've driven off several times with the parking brake on not realizing it because there is almost no difference. I was going to do the minor adjustment like the last gen RDX has, as well as a few other Acura models that I've seen, but there was no adjustment nut on the cable by the pedal, at least that I could see/feel. Does anyone know how to adjust the parking brake to actually hold the car, or is it even possible to perform a "minor" adjustment? It isn't an issue to adjust them at the wheel, but I'd like to avoid that if there is another way. TIA.
imnuts is offline
Old 08-29-2014, 12:23 AM
Registered Member
X2 above
mdfree is offline
Old 08-29-2014, 09:36 AM
Registered Member
May not be what is needed here; but, last trip in I had the dealer adjust the travel of the pedal. Ours bottomed out when my dainty darling put her foot in it and I actually had a little trouble dis-engaging it! Their adjustment seemed to do the trick. Perhaps yours is similar?
By the bye, we can reverse with the brake engaged; but the RDX puts up a mighty battle when we try to drive off with the parking brake set (Nah, we don't do it that often...just a couple of times )
CoachRick is offline
Old 08-31-2014, 08:08 PM
Registered Member
We already tried to get the dealer to adjust it, twice. They keep telling us that it is within specification. The parking brake does next to nothing, whether it's reverse or drive. I'd like to know how to adjust the parking brake, either a minor or major adjustment, so that it works the way it is supposes to.
imnuts is offline
Old 08-31-2014, 10:16 PM
2015 RDX Tech AWD
Try another stealer....
ARascal is offline
Old 09-01-2014, 09:31 AM
Registered Member
Well, the dealer we go to is <5 miles away and a 10 min trip at worst. While there are several other dealers around, I'd rather not be driving the 30-45 minutes it's going to take for a one time trip, and for them to tell me the same thing. I'd rather just know how to perform the adjustment myself. I've tried finding a service/repair manual, but I can't even find those for the 2013+ RDX.
imnuts is offline
Old 09-01-2014, 01:52 PM
Registered Member
I wonder if there is some kind of tie in between the emergency brake and the fact that the engine is running and the car put into gear. Maybe it works fine when the engine is off and it is in park but releases to a large degree when you actually move the car on purpose so it doesn't damage itself. Just a thought as I really don't know if it is that sophisticated or not.
geocord is offline
Old 09-01-2014, 02:27 PM
Registered Member
musty hustla's Avatar
Note that the RDX has a PARKING brake, not an EMERGENCY brake. In an emergency situation, the emergency can be used to stop a car safely. The parking brake is used as a safety measure to prevent the car from rolling.
Here's how you test your parking brake: park on a slope, engage the parking brake, put the car in neutral, and take your foot off the brake. If the vehicle doesn't roll, the parking brake works.
musty hustla is offline
Old 09-01-2014, 06:23 PM
Registered Member
Parking/emergency brakes are strictly mechanical (or electromechanical) and will work the same regardless of whether the engine is running or not. The RDX is a cable driven setup, I just don't know where to adjust the cable tension. I haven't tried to have the car in neutral on an incline with the parking brake engaged yet, but I do plan on trying that. I know in reverse, idling on an incline, the vehicle moves freely, so I can't imagine neutral will change much.
Also, parking/emergency brakes could stop the car if needed, but they will take significantly longer to bring the car to a stop as it is the rear brakes only, which are always much smaller than the front brakes. They're better than nothing, but stick with your primary brakes unless they're completely dead.
imnuts is offline
Old 09-01-2014, 08:11 PM
Registered Member
When we looked at a Subaru Outback a year ago, the parking/emergency brake was operated with a push button on the dash rather than a pedal on the floor or a hand lever on the console. I had not seen that before and I wasn't sure I liked it, though the salesman pushed it as a feature. It seems like that must have been at least partly electronic and not strictly mechanical.
Gregg
vbgregg is offline
Old 09-05-2014, 05:32 PM
Registered Member
Gregg
The brake portion is still mechanical, just that it is engaged by a switch rather than a direct cable. It should still function even if the hydraulics fail.
And I'm guessing that no one knows how to adjust the parking brake given that no one had responded with anything about adjusting it.
imnuts is offline
Old 10-01-2014, 02:49 PM
Registered Member
cable actuated parking brakes should be pushed harder than normal due to the long cable "stretching". It's adjusted at the rear brake caliper I'm guessing since my wifes CR-V is there.
dawudih is offline
Old 10-03-2014, 03:19 PM
Registered Member
Just looking at the parts diagram it looks straightforward as long as you can get to the adjusting nut. It's #12 in the diagram and list below. Basically a single cable runs from the pedal to a splitter (or "equalizer" in Hondaspeak, part #9), and then cables run from the splitter to each wheel. The parking brakes themselves are just small auxiliary drum brakes on the rear wheels that are actuated by the cables. Tightening/loosening #12 adjusts the tension on both of the rear cables equally so you don't have to adjust each wheel individually. A similar setup is used on tons of other Hondas so it shouldn't be anything your dealer would have issues with. Searching for the equalizer and adjuster nut part numbers shows the same parts in different years of Civics, Accords, Fits, CRVs, even NSXs.
All that being said, I haven't personally done this on my RDX yet so I'm not sure exactly where the equalizer is. On Civics and Accords with handbrakes it was generally just behind the handbrake itself, but going off the diagram it looks like it's somewhere in the middle of the floor on the RDX. My guess is under the carpet around the center console somewhere so it's not getting corroded hanging under the car, but maybe somebody else can chime in on that.
If you do end up adjusting it, I'd recommend chocking the front wheels, putting it in neutral, jacking up the rear end, and checking how freely the rear wheels spin before and after adjustment. This is just to make sure you don't tighten it to the point that the brake is still rubbing even with the pedal fully retracted. If this adjustment still doesn't get you what you need, there's also a way to adjust each wheel individually (a "major" adjustment vs. the "minor" adjustment described above, per Honda lingo). It's a bit more involved though as you need to take the wheels off to get to the actual parking brake drums so you can adjust the brake shoes themselves. Generally a minor adjustment will get you what you need though.
Scheffy is offline
Old 12-06-2016, 04:23 PM
Registered Member
Joe Las Vegas's Avatar
Is the parking brake one side or both?, Mine only locks the rear left wheel.
Joe Las Vegas is offline
Old 12-06-2016, 05:58 PM
Registered Member
Brown13's Avatar
Here's a procedure for adjustment on an older Acura.It is the same for newer Acura as I have adjusted My 2013 RDX.
Brown13 is offline
mascalif (04-14-2019)
Old 04-14-2019, 09:49 PM
New Member
Good video. Nice lighting.
mascalif is offline
Old 04-18-2019, 07:22 AM
Inveterate Tinkerer
Gadgetjq's Avatar
Does anyone know how to adjust the parking brake?.
Check out this forum thread.
Cheers!
Gadgetjq is offline
Old 04-18-2019, 08:14 AM
Registered Member
Tech's Avatar
Brand new, it does nothing. I've never seen such a useless parking brake.
Tech is offline
05-09-2019 10:33 AM
rockyboy
Second Generation RDX (2013-2018)
166
11-04-2018 12:03 PM
stalloutboy
04-25-2016 10:28 PM
jliu6789
Second Generation TL (1999-2003)
09-08-2015 08:02 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: Parking Brake Adjustment
