Panel above accelerator brake missing after service!!!?
Hello all,
I was just cleaning up my 13’ RDX and found that the panel with all the wiring above the above above the brake and accelerator pedals are exposed completely which actually looks ugly. I am not sure if there was a black plastic panel covering all this and it was removed during a service . Can someone confirm if there is there a plastic black panel to cover up on these on your rdx’s and if its just me?I haven't checked this part in a long time
Also on the other side I am seeing some missing lining below the glove box. If you could confirm this a well.Thank you Appreciate it
Driver side Panel missing!!!?
Passenger side below glove box patch of liner missing!!? What the heck
I just checked our 2013 RDX with FWD and Tech. It looks the same as yours.
On the one hand, you can't even see the fuse box unless you stick your head almost on the floor. On the other hand, if you had muddy or snowy boots, it would be nice to have a cover to keep the mud or snow out of the fuse box if your foot gets a little too close!
Similarly, the missing piece of floor lining on the passenger side can't be seen unless you stick your head almost on the floor. But it does seem odd that a little section is missing. I'm not sure why that is.
In any event, our RDX looks the same as yours.
Gregg
Gregg
sj123 (09-13-2014)
Gregg
Gregg
Gregg!! thank you for taking some time to take a look, phew, so i don't need to do anything here.... thanks again. Appreciate the fast feedback
It's the same in all RDXs I guess. I just checked mine and it's exactly the same ( even the corner at the passenger side). It would be the least of my concerns anyway since it's so hard to go and see them with eyes. It's easier to take a picture and visualize. Would I like it covered...? Sure.
On a lighter note I believe the OP would not have any holes in his socks.
So I guess it had nothing to do with the dealer service
It is soooooo easy to blame the dealer for everything.
asahrts
09-04-2015 05:55 PM
