No struts for rdx - AcuraZine - Acura Enthusiast Community
Notices
No struts for rdx
Old 02-05-2019, 08:27 AM
Registered Member
No struts for rdx
I need to replace on on a 2014 rdx for clunking at 30,000 miles. So I will do both but can't find one anywhere. Told on national back order. and new ones won't go so fast. E=bay has them but why buy a strut that will fail, will wait.
hovbuild is offline
Old 02-05-2019, 08:32 PM
Registered Member
Rear shocks you have OEM and KYB to pick from. For the front struts , it's only the OEM. I'm switching over to the KYB as soon as it warms up a bit more.
Poolman is offline
Old 02-08-2019, 01:11 PM
Registered Member
It is really doubtful that the front struts would need replacing at that age & mileage. I would check other items first. In some Hondas there was a service bulletin on the top strut mount,
not sure if that involved this vehicle.
egads is offline
Old 02-08-2019, 01:59 PM
Registered Member
Rear shocks are noted for going bad and making clunking sounds. Happened to me once, covered under warrentie.
Poolman is offline
Old 02-09-2019, 06:35 AM
Registered Member
It sounded like a sway bar bushing and there was some play on both so I changed them. Did nothing but cost me 100.00. Engine mounts were fine and every component that would rattle in the effected area was checked. Only thing left was the strut. The rattle only happens when driving slow over small bumps and can't be reproduced on a lift. All possible suspects have been ruled out.
hovbuild is offline
XDR3102
2G RDX Problems & Fixes
12-25-2018 10:40 PM
mav888
1G RDX Tires, Wheels & Suspension
05-26-2017 08:01 PM
air4me
Second Generation RDX (2013-2018)
05-07-2014 07:37 AM
dark inspire
21
03-14-2005 05:03 PM
SilverKnight
Second Generation CL Discussion (2000-2003)
03-07-2002 09:34 PM
Quick Reply: No struts for rdx
