Jewel Eye LED headlights for 2013-2015 RDX model
I wonder whether new Jewel LED headlights could be installed
on 2013-2015 Acura RDX. If Acura offers it as an accessory option, I will be among the first to put them on my car. It looks like headlight dimensions are the same, (not sure about electrical, though). Also the new "beak" looks a little bit better.I wish they would make it easy to install and swap the current one.:thumbsup: |
If we kept the rdx the plan for me was to get the rear lights and front lights.
From quick glance, you'll probably need the bumpers and grills too since it looks like the slope of light is a little wider and if you look up retrofitted audi q5 lights, it will give you a sense of random wiring upgrades that might be needed from HID to LED (since the parts aren't avail yet in computer) hard to see what exactly is needed) |
Agreed... you will need new front bumper not to mention mount points and wiring. Wouldn't it be easier and more cost effective to just upgrade to a 2016 if you love the LED's that much? You will be getting all the other 2016 updates too.
Originally Posted by CybrRdr
(Post 15347147)
Originally Posted by ceb
(Post 15347172)
Yes. I suspect the fenders and hood may be different as well. You'll also need to consider the lights themselves (probably $4k for the pair) so parts will probably run in the $6k range. Then there is paint and labor...
Even at Acura i think NEW is 1400 ish. Better off buying from a rear ended 2016 since you'll be able to get everything in one full shot AND depending on color maybe even already your color (meaning bumper grill hood etc included or whatever else is needed |
$ wise probably better off buying a 2016
Originally Posted by Type X
(Post 15347232)
No way that high for the lights, if you're patient you'll find them on ebay for under 900 for the set.
Even at Acura i think NEW is 1400 ish. Better off buying from a rear ended 2016 since you'll be able to get everything in one full shot AND depending on color maybe even already your color (meaning bumper grill hood etc included or whatever else is needed I can only guess at the price of the RDX lights but IIRC the RLX lights are in the $2k range. I know the bodyshop charged $1000 for a single 2005 RL headlight assembly. |
Originally Posted by Doubtit
(Post 15347253)
Exactly. There's not much financial sense in retrofitting LED lights to the current RDX. To me the Xenon lights are fantastic. But f you already have the base model with halogens, then may be you could consider. ....???
Originally Posted by Comfy
(Post 15348567)
unless!!!!!!!!
you get into a front end collision and you have the body shop buy the 2016 stuff instead of the 2013-2015 stuff. then; all it cost you is your deductible. Assuming the 2016 stuff cost about the same as the 2015 stuff. |
(Post 15348737)
unless!!!!!!!!
The "Jewel Eye" marketeers must be laughing up their collective sleeves. :rolleyes:
I have 2014 RDX Base AWD and do not like the standard halogen headlights. They are ok but nothing special. Replacing with HID or jewel LED headlights will be expensive and will void the warranty as they are not offered as factory accessories.
Do you guys think if adding fog lights will improve low beam visibility at night. I can get them installed for $500 (parts+labor) at the dealership? |
^no, because fogs are intended for FOGGY situations....
hence why they are called fog lights |
Maybe upgrade your stock Halogen H11 bulbs with something brighter.. like Silverstar Ultras.
Originally Posted by larryradev
(Post 15350040)
I have 2014 RDX Base AWD and do not like the standard halogen headlights. They are ok but nothing special. Replacing with HID or jewel LED headlights will be expensive and will void the warranty as they are not offered as factory accessories. Do you guys think if adding fog lights will improve low beam visibility at night. I can get them installed for $500 (parts+labor) at the dealership?
Like the previous poster suggested switch the bulbs to brighter halogens (4300K) from sylvania, Philips or Osram or HIR bulbs. The improvement would be marginal at best though. If I were in your situation I would look into retrofitting HIDs into your lights. I know it'll void the warranty of lights but if you use a separate relay harness it should not affect the electrical system of the car ( and the related warranty). You could do a wonderful HID retrofit with $1K. Why? Because it's worth it. Once you move over to HIDs it's very hard to come back to halogens. The other more expensive and not so good option is to trade into a tech model. Good luck. |
(Post 15350040)
(Post 15350052)
hence why they are called fog lights Fog lights are designed to light up the area directly in front of your car. This is exactly what you don't want for driving in clear conditions. When you look out your windshield at night you see this unlit area directly in front of your car. It is there intentionally. The eye is drawn to the brightest area, so farther away from the front of your car is better. Adding fogs and using them during normal driving would draw your eyes to the area directly ahead of your car and reducing your distance vision and would reduce your ability to react to hazards in time. You only want to use fogs in fog - when you are driving slowly and hazards will be closer. |
I'll consider swapping the tail lights for the new LED if it's simple to do. I like the xenon headlights. Although it would be nice to somehow turn the daytime lights into a cool LED. I don't like their current yellow'ish color.
Originally Posted by ottoman101
(Post 15350408)
About the tail lights, let's wait and see. I'm guessing it won't be an all out LED unit, just the tail light (the brake and turn signals would likely still be halogens) Is it worth it in that case...??? |
(Post 15348737)
unless!!!!!!!!
(Post 15350040)
Wiring
Just got a set of jewel LED headlights off a 16 RDX to put into my 13 base.
Does anyone have the wiring diagram (2016-2017) for these cars? If I can only figure out what to plug where. |
Do they fit without modifications?
Wow...this must be a first. This thread has suddenly come alive after a few years. :D.
Let us know how it ends up. |
Originally Posted by awoc
(Post 16198541)
"awoc" has not replied in nearly a year since he got the LED headlight parts. My guess is that the conversion was not possible.
You should stop posting false information, and actually look at what's posted. Modify at your own risk. Enjoy.
https://acurazine.com/forums/2g-rdx-performance-parts-modifications-407/16-led-headlight-conversion-13-15-a-969246/ |
(Post 16376171)
https://acurazine.com/forums/2g-rdx-...3-15-a-969246/ Oh my bad. It was nice of you to update this thread. Thanks. OMG. Just went though the thread, that looks like a very much involved and in depth mod. Congratulations on having a unique RDX now. You are very mechanically / electrically talented and resourceful member. |
2013 rdx headlights upgrade
(Post 16376171)
https://acurazine.com/forums/2g-rdx-...3-15-a-969246/ |
