Interior lights do not work
Bought a FWD w/ Tech the other day and I realized the next day that the interior lights do not come on when the door is opened. The ceiling light in the rear will also not come on when sliding the switch to "on".
Also, is there any lights in the front that should come on when the door is opened, i.e. map lights? The door lights do illuminate.
Am I missing something or do I need to go back to the dealer and have this looked at?
There should be 3 settings. "Off", "Door", and "On". Make sure all lights are set to "door". Also, Check to make sure its programmed correctly on your trip computer. Go to "Customize Settings" Refer to owner's manual if needed. If that doesn't work then call your dealer and they can take care of it for you. When the car arrives at the dealership from the factory, all lighting/electrical is off and disconnected, they may have forgotten to turn the interior lights on prior to delivery. I doubt the fuse is blown on a brand new car, lol.
Car Crazy for Sure!
Just saying....folks, this easy stuff is in the manual. Please take the time to look through it, you'll be amazed at what you might find out. I still haven't read it all yet....or the Nav. one.
Good luck, Jim
Car Crazy for Sure!
I know Jim, I have it all downloaded in pdf files. It's whatever is easiest for each person....but, everyone has the Manual.....some may not be able to download those large pdf files. Just thinking.
rockyboy
01-25-2016 06:00 PM
wusty23jd
09-24-2015 11:41 AM
drewdeezy03
09-03-2015 08:04 PM
