How much brake fluid
Old 08-21-2018, 01:03 PM
4th Gear
newbee01's Avatar
Hi All,
I have about 55K Mile on 2015 Acura RDX and i think it is time that i take it for the brake fluid change. However, I plan on taking to the local auto shop and don't know how much brake fluid i need for the job. I plan on buying Acura fluid online. Any suggestion on how much to buy and from where?
Old 08-21-2018, 01:06 PM
Received 16,260 Likes on 11,971 Posts
check your owners manual...will have fluid capacity amounts.
Old 08-21-2018, 02:41 PM
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
Old 08-21-2018, 03:14 PM
losiglow's Avatar
You don't have to buy the Acura brake fluid. Any DOT4 fluid will work just fine. Either way, I personally use about 1.5 quarts to flush the entire system. I'm not sure what size bottles the Acura stuff is sold in but I'd get at least that much. And if you have extra, you can keep it to top the fluid off when needed.
Old 08-21-2018, 05:50 PM
4th Gear
newbee01's Avatar
Thank you. I just finished reading the manual and the only fluid that doesn’t have any capacity information is the brake fluid :-(
but I am going to follow your suggestion :-)
Old 08-23-2018, 09:37 PM
alpha2beta's Avatar
Originally Posted by newbee01
Hi All,
Just changed the brake fluid in my wife's RDX last night I ordered 3 12Oz bottles of Amsoil and ended up using 2 and 1/4 bottles of fluid, I also drained the brake reservoir before starting so I wouldn't waste so much trying to get the old fluid out.
boorah623
10-10-2016 06:30 PM
Putthead
01-13-2011 09:30 AM
idkjai
08-12-2009 11:16 PM
vtec1jk
02-21-2007 07:53 PM
CLSinTO
11-09-2001 01:38 AM
Quick Reply: How much brake fluid
