Notices
How to lock you key fob in your car
Old 07-11-2019, 04:20 PM
Registered Member
I do a lot of kayaking and mountain biking. We often need to shuttle the car to the end of a ride. Typically you give an extra key to the shuttle driver. He parks the car at the take out, leaves the keys under the seat, locks the car and walks away.
I can not find a way to lock the car with the keys under the seat. Is there a way to do this?
Thanx
Ron
Ron206 is offline
Old 07-11-2019, 04:39 PM
Received 5,933 Likes on 4,758 Posts
can you take out the battery perhaps?
thoiboi is offline
bldrdx (07-11-2019)
Old 07-11-2019, 10:10 PM
Registered Member
I've never tried it, but to prevent a signal between the key fob and the ignition perhaps you could wrap the keys in aluminum foil or place them in a small metal box to see if that would work.
snorf is offline
Old 07-11-2019, 10:35 PM
Registered Member
I've tried 3 different methods of shielding the key fob with no success.
Removing the battery may be the only way. Just a little worried that a shuttle driver will do it (or do it correctly).
So no way to configure the lock system to allow this? (I did scan through the options several times, tried a few changes, no luck)
Ron
Ron206 is offline
Old 07-11-2019, 10:56 PM
Registered Member
dopeboy1's Avatar
I believe you need to put it in a lead lined box
dopeboy1 is offline
knovak17
Second Generation RDX (2013-2018)
12-21-2017 09:13 AM
Negative1
05-11-2014 11:53 AM
Sgt128
3G MDX Discussion (2014+)
02-23-2014 09:39 AM
PsychDoc
Fourth Generation TL (2009-2014)
19
07-16-2009 10:03 PM
2000 TL
Second Generation TL (1999-2003)
11-02-2006 09:04 AM
Quick Reply: How to lock you key fob in your car
