Which gas is better?
Old 09-28-2015, 12:05 PM
3rd Gear
San Yasin's Avatar
Arrow Which gas is better?
Greetings all, I have a 2013 RDX. I live in the southeast of U.S. where they put ethanol in most gas. Is it better to buy the Acura recommended 90 or higher octane with ethanol in it or go with the lower 87 octane that has no ethanol in it? I've always heard better to have no ethanol as the engine will perform better, however, Acura recommends the high octane gas.
Old 09-28-2015, 12:17 PM
mrgold35
mrgold35's Avatar
Received 1,508 Likes on 1,176 Posts
Do you know if mid-grade is free of ethanol? That would seem to be the lesser of two evils of lower octane 100% gas compared to higher octane with 10% ethanol+mpg hit.
Old 09-28-2015, 12:21 PM
2021 RDX A SPEC
Acura604's Avatar
I will ONLY put in 91 / premium grade.
Old 09-28-2015, 12:27 PM
Received 16,260 Likes on 11,971 Posts
Butt Butt, what if your state offered Non-ethonol 93 octane?
because we are not arguing which fuel is recommended but which fuel burns at the optimum time
Old 09-28-2015, 12:50 PM
2021 RDX A SPEC
Acura604's Avatar
meh...I'm in Canada...got no non ethanol choices
justnspace (09-28-2015)
Old 09-28-2015, 01:00 PM
Here in the states, where the political agenda is $$$, they push corn, which lowers the ability of gas to burn efficiently.
so, it's pretty much a toss-up. I know where ever I go to fill up, I will always have ethonol in my fuel. so, 93 octane is as best as I can get.
Old 09-28-2015, 01:22 PM
3rd Gear
San Yasin's Avatar
Here in GA/SC the only non-ethanol choice we have is 87 octane.
Old 09-28-2015, 01:23 PM
^yeah, i wouldnt use it.
Old 09-28-2015, 01:33 PM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Don't the pumps do in situ mixing of the high and low octane fuels to get midgrade?
So running the mid would still result in an percentage of cornahol, and my maths say it would be roughly 50% of what would be present in the high oc.
I'm not sure my inputs helped anything...
EDIT: except to say that running mid grade might be the best of both worlds... or the worst... Not sure.
Old 09-28-2015, 01:36 PM
^going off what cu2wagon said; I dont think the corn lowers the efficiency of the fuel that much to where it is equal to pure 89 octane
Desert Ridge's Avatar
Avoid ethanol at all costs.
Old 09-28-2015, 01:37 PM
All of our fuel has it. It cannot be avoided where I live.
Old 09-28-2015, 01:41 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
What? Where? Across Alberta, all 91 is ethanol free.
87, 89 and 94 all have ethanol here.
Old 09-28-2015, 01:43 PM
TacoBello's Avatar
You are correct, however, I don't exactly know where the mixing occurs.
Here, regular (87) has 10% ethanol
Premium (91) has 0% ethanol
Mid grade (89) is just a 50/50 mix of the above, and has 5% ethanol.
I believe the 94 we have here has 10% ethanol, also.
Old 09-28-2015, 02:04 PM
hand-filer's Avatar
meh...I'm in British Columbia...got no non ethanol choices
There, I corrected that for you. Other parts of Canada have choices. In most cases regular contains 10% E, mid grade 5% and premium 0%.
Old 09-28-2015, 03:07 PM
ceb
ceb's Avatar
Received 1,276 Likes on 951 Posts
Let's not confuse octane and ethanol. In theory, ethanol has a higher octane rating than gasoline, but at the 10% where we are in the US, there is little noticeable difference in octane ratings. The energy content of ethanol is about two thirds that of gasoline, so your E10 should yield about 3% lower gas mileage. In real life testing however, the gas mileage hit has been much greater.
Some regions have also been doing E15...
Old 09-28-2015, 06:03 PM
Make it #7!
5 Acuras's Avatar
Non ethanol recently became readily available around here, 91 octane only. I use it in both Acuras and my Vintage rides. More expensive, supposedly better for seals, gaskets, etc. in the old cars, small engines, etc.
Old 09-29-2015, 12:15 AM
rockyboy's Avatar
I use super premium 91 Octane containing zero ethanol. It is about 10% more expensive than regular gas but also gives me better mileage and is better for my engine health and performance so the price difference is negligible. I've been getting a range of 600 - 700 km on one tank of fuel. Varies depending on how long a stretch I go with less stop and go traffic and how fast I'm going. Also, I've been taking it easy on the gas pedal until I break in the engine.
Old 09-29-2015, 06:28 AM
3rd Gear
San Yasin's Avatar
Thanks everyone. It looks like there is no solid answer but to seek out non-ethanol gas when you can and hope it is high octane.
Old 09-29-2015, 08:35 AM
rockyboy's Avatar
The solid answer is go for 91 Octane or higher with no ethanol (ethanol may not be good for the engine).
Old 09-29-2015, 10:40 AM
CanWat's Avatar
Shell highest grade Vpower (91 Octane) is ethanol free, here in Ontario.
Old 09-29-2015, 10:52 AM
rockyboy's Avatar
Yep and Canadian Tire gas bars 91 Octane or Costco 91 Octane along with a few others like Shell and Petro Canada
JDM96specCTR
10-17-2015 01:06 PM
xsilverhawkx
10-05-2015 11:00 AM
MilanoRedDashR
10-02-2015 10:49 AM
Skirmich
10-01-2015 12:59 PM
Quick Reply: Which gas is better?
