FOB dead after battery replacement
The messager that battery was low on my FOB showed up on dashboar ... . Bought new 2032 CR battery, replaced it and now FOB is dead i.e. car
does not reponds . Are there an additional steps to pair with the car ? Should I give another battery a try ...?
What model year is your RDX?.
If none of these things are happening, especially the LED's not lighting, then
- Do the doors unlock when you reach behind the door handles (i.e. FOB still in your pocket).
- Does the FOB unlock your doors (including the hatch) from a distance when you use the unlock-lock-hatch buttons on the FOB?.
- Do any LED's light up on the FOB when you press a button?.
- your new battery is probably dead
- your battery is installed backwards
- your FOB is defective
Also try putting in your old battery. It should still work with the warning message that battery is low. Why don't you buy a new battery (from a different shop) and give it a try? It's only a few dollars. All batteries have a limited shelf life whether used or not. It's very unusual for a keyfob to simply malfunction (though not impossible). Let us know what happens.
I did the same thing and the new battery was dead. Tried a different one and all good. Some of those made in China batteries are pretty unreliable
