Notices
Driver side Front Turn Signal (how to reach)
Old 12-02-2018, 01:14 PM
New Member
Hello!
I am new here, I would like to replace my front turn signal on the driver side but what is hindering me is the space. The battery is almost blocking the way. I could not fit my arm properly and when I do, my arm is restricted and could not turn the light bulb socket.
Could you provide me tips and tricks if you have changed this side of the turn signal before?
PS. the passenger side was no problem a lot of room there.
Thank you in advance
js.marcelo is offline
Old 12-02-2018, 01:59 PM
Registered Member
Carefully remove the push pins on the wheel well cover by the front turn signal. Then get your arm inside and turn the turn signal socket to remove bulb.
dave08902 is offline
colt427 (12-02-2018)
Fred'sTSX
Second Generation TSX Discussion (2009-2014)
12-16-2018 11:17 AM
Quick Reply: Driver side Front Turn Signal (how to reach)
