Notices
Check Emissions System
Old 05-07-2018, 06:18 PM
Registered Member
Recieved 0 Likes on 0 Posts
2014 with 160K miles. Lots of highway driving. Yesterday evening I got this alert while driving home to Denver from Kansas City. Immediately I felt the engine struggle when accelerating. It would shake. No dealerships open on Sunday evening in KC. I decided to just get home. I did. If you are aware, the altitude goes up by 4000 feet and the car struggled whenever I had to climb even a little. I remember this with my previous car, VW Touareg. It turned out to be ignition coils with that one. I wonder what is wrong with this. It was not a fun drive.
wallmike is offline
Old 05-07-2018, 07:07 PM
Registered Member
Brown13's Avatar
Recieved 33 Likes on 28 Posts
Check for codes.If You don't have a reader,most auto parts stores will read for free.They may also suggest a fix. Worth a try.
Brown13 is offline
Old 05-07-2018, 08:45 PM
Registered Member
Just did a test drive and it is back to normal. No hesitation when accelerating. The light is still on though.
Well have the code checked.
wallmike is offline
Old 05-09-2018, 08:34 PM
Registered Member
Went to Autozone and pulled codes.
P3400 Valve Pause System (VPS) stuck off Bank 1
P0138 H02S S2 High Voltage
At this time, the vehicle is running normally. The check emission system light is still on.
wallmike is offline
Old 05-10-2018, 08:08 AM
Registered Member
Brown13's Avatar
It appears that an oil sensor switch needs to be replaced. Google is Your friend. Here is a Youtube for a different model ,but switch will be in same location..
Brown13 is offline
Old 05-20-2018, 12:22 AM
Registered Member
Thanks for the info.
The problem went away during this week's travel to Vegas. The car ran fine and didn't complain even during the steep inclines in the Rockies.
wallmike is offline
Old 01-06-2019, 09:58 PM
Registered Member
Originally Posted by Brown13 View Post
It appears that an oil sensor switch needs to be replaced. Google is Your friend. Here is a Youtube for a different model ,but switch will be in same location.. https://www.youtube.com/watch?v=GlorN9b4D9Y
I did this and problem went away. Dealer asked for $330 for labor alone. No, thanks.
Bought two of the parts from Amazon and it was a breeze.
Thanks.
wallmike is offline
G&V
1G RDX Problems & Fixes
19
01-05-2019 09:59 AM
wmahmud
4G TL Problems & Fixes
41
01-03-2017 11:12 AM
Midnight Mystery
First Generation RDX (2007-2012)
03-22-2016 12:16 AM
zoope
Second Generation RL (2005-2012)
08-07-2011 02:20 AM
helraiser
1G TSX Problems & Fixes
05-26-2008 10:35 PM
Quick Reply: Check Emissions System
