Brake squeal
Old 07-11-2019, 07:38 AM
tinmaner's Avatar
Brake squeal
so i have been getting squealing in brakes and little squealing when taking full turns and has been complaining to Acura dealer since around January of this year .. they simply said its a glaze formed on the brake pads cause i dont drive much .( i know stupid answr)
finally made them take a deeper look at it and here is the response
" The brake squeal he practically heard almost immediately. Once he inspected the brakes, he saw that the front brake shims and backing plates were a too close together and were causing the squeal when driving and when turning. He had to disassemble the front brakes to be able to adjust them and lubricate them properly."
Question - - is there something in there that could have had a damage cause of this ? more wear than normal or something like that ?
Old 07-11-2019, 08:20 AM
Mo_Green's Avatar
At 30k the brakes need to be taken apart and lubricated. My vehicle had the same issue with squealing brakes in a slow turn. Use silicon high temp brake grease on all metal to metal contact points. A small smear on the brake back plates as well. Finally a small squeeze into each pin boot too.
Consider this a normal mainentance item.
Old 07-11-2019, 09:32 AM
tinmaner's Avatar
30K ? my vehicle is a year old with 3k miles on it
Old 07-11-2019, 10:39 AM
Mo_Green's Avatar
Quality is way for today's vehicles. Engines are the most reliable they have ever been. But for the rest of today's vehicles. No way.
Old 07-11-2019, 12:33 PM
tinmaner's Avatar
Exactly how i feel about Acura .. Engine is the only thing that is way more quality than competitors .. and with v6 .. its getting hard to keep it under 40 mph on local roads rest of the car they employed bad cost saving tactics and no attention to detail at all '
Old 07-14-2019, 12:34 AM
Base2014RDX's Avatar
ost likely the dealer replaced the retainer clips (the guy in the video calls it "shim") or just re-lubed and re-seated the old clips.
Most likely there was no damage to begin with.
Old 07-14-2019, 12:46 AM
Not better engine quality, just more conservative (thus proven) designs. We are talking about timing belt, lack of direct injection, and valve adjustment at 100,000. The RDX was ridiculously behind in tech.
Old 07-14-2019, 10:08 AM
acuratech481's Avatar
This is a known issue on these vehicles due to a manufacturing defect. If you're still getting the squeal take it back. There's updated brake pads and rotors depending on the date and casting numbers on the front rotors. The updated front pads have a longer chamfer on the bottom side of the inner brake pad.
Old 07-19-2019, 09:37 AM
2014 RDX AWD Tech
Comfy's Avatar
My RDX has also started a break squeal now especially on cold starts in the morning. I had the discs and pads replaced a few years ago under warranty for the same issue. The noise doesn’t bother me much but that video posted above is making me concerned.
Old 07-21-2019, 04:13 PM
comanche250's Avatar
I just posted the same issue in another area on this forum. Squealing from left front wheel when turning left (18 rdx 23k miles) Loud enough people look at you. Dealer said every thong looked fine.. A week later swelling again just as loud. What do you suggest I dealer what they need to do?
Old 07-21-2019, 04:21 PM
While turning makes me think it's the shifting of the brake caliper bracket hardware. The piece that the brake pads sit in touches the rotor. Another common issue...
Old 07-21-2019, 04:23 PM
Or the rotor backing plate is scraping against the rotor. This is easily overlooked sometimes as it isn't always bent enough to cause a noise when going straight therefore not being able to duplicate it on the lift.
Old 07-21-2019, 04:41 PM
Thanks for the help.
Old 07-22-2019, 09:08 AM
tinmaner's Avatar
Basically they said the Brake shim on the left is turning along with the wheel and it is not supposed to ..
the service guy said they readjusted them and lubricated them but i am still hearing the sound. i might take it back in again but its such a pain to deal with ..
yes they are giving a loaner but its not the same as driving your own vehicle :-/
the main reason i went with a new Rdx instead of a preowned BMX x3 (they are at exact price point x3 is 2018 at 7k miles) is to avoid these kind of visits .. very disappointing.
Old 07-22-2019, 09:46 AM
Bob_Durk's Avatar
Talking Brake Noise Cured Itself
After sever trips to the dealer who was unable to solve the issue, after about 5,000 miles the noise finally went away.
WDPTL
05-01-2013 05:48 PM
SodaLuvr
05-24-2007 07:47 PM
Tommy_boy
09-16-2005 08:13 PM
3PUTT
03-18-2004 09:26 AM
Mr. Bill
01-02-2004 11:02 AM
Quick Reply: Brake squeal
