2018 Acura RDX Technical Service Bulletins
2018 Acura RDX Technical Service Bulletins:
TSB 17-024 - 2018 RDX: TQI Information Applies To: 2018 RDX - 2WD 2018 RDX - 2WD with AcuraWatch Plus Package 2018 RDX - 2WD with Technology Package 2018 RDX - 2WD with Technology and AcuraWatch Plus Packages 2018 RDX - 2WD with Advance Package 2018 RDX - AWD 2018 RDX - AWD with AcuraWatch Plus Package 2018 RDX - AWD with Technology Package 2018 RDX - AWD with Technology and AcuraWatch Plus Packages 2018 RDX - AWD with Advance Package http://www.urvi.net/forumfiles/SB/B17-024.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-024.PDF TSB 17-025 - 2018 RDX: TQI of the Navigation System Applies To: 2018 RDX - All with Navigation http://www.urvi.net/forumfiles/SB/B17-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-025.PDF TSB 14-025 - Timing Belt Chirps Applies To: 2016-18 RDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B14-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B14-025.PDF TSB 17-049 - Brake Judder (2013–18 RDX) This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder. This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX). http://www.urvi.net/forumfiles/SB/B17-049.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF TSB 18-008 - Navigation Showing Inaccurate Location Applies To: 2017-18 RDX - ALL with navigation - ALL http://www.urvi.net/forumfiles/SB/B18-008.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-008.PDF TSB 19-009 - Front Brake Noise and/or Front Brake Judder This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX). Applies To: 2013-18 RDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-009.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram Applies To: 2007-18 RDX http://www.urvi.net/forumfiles/SB/B19-059.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-059.PDF TSB 20-038 - Steering Wheel Rattles Applies To: 2016-18 RDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B20-038.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-038.PDF TSB 23-029 - Warranty Extension: 2017-18 RDX 6AT Torque Converter – DTC P0741 Stored Applies To: 2017-18 RDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-029.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-029.PDF TSB 23-035 - MIL Comes on with DTC P0441 Applies To: 2018 RDX - ALL - ALL http://www.urvi.net/forumfiles/SB/B23-035.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-035.PDF TSB 23-038 - Safety Recall: Multi-Model Acura Fuel Pump Motor Stop Sale Applies To: 2014 RDX (AWD) - Tech - Check the iN VIN status for eligibility 2018 RDX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B23-038.PDF http://techinfo.honda.com/rjanisis/p...nu/B23-038.PDF http://techinfo.honda.com/rjanisis/p.../B23-038v4.PDF (Link works, but is wrong) Version 4 |
