Notices
2016 RDX CPO - Brake Concern. Should I buy?
Old 06-12-2019, 05:19 AM
New Member
I am in the process of purchasing a 2016 RDX advance. The CPO report indicates the following regarding the brakes:
The left front brake pad is 6 mm
The right front brake rotor is 24 mm
The left rear brake pad is 7 mm
The left rear brake rotor is 8 mm
The right rear brake pad is 7 mm
The right rear brake rotor is 8 mm
Do these numbers indicate that the brakes need to be replaced soon????
Rruthlyn is offline
Old 06-12-2019, 10:11 AM
Registered Member
Pad thickness' look fine to me...the rotor however is probably at or below minimum. Were it me...I would negotiate new rotors and pads all the way around.
jjrphs is offline
Old 06-12-2019, 11:24 PM
Registered Member
Pads look fine, but those rotor numbers cannot be correct. But regardless, it's a CPO, so it's all covered under warranty is it not?
DUCRDX is offline
Old 06-13-2019, 09:41 AM
Registered Member
CPO is another name for used. IF you have any doubts about the brakes you should probably take care of it BEFORE buying as it will be difficult getting anything done at their expense once you are the owner.
snorf is offline
Old 06-15-2019, 08:12 AM
Registered Member
Front pads
Brake pad thickness:
Standard: 11.0 mm (0.433 in)
Service limit: 1.6 mm (0.063 in)
Rear pads
Standard: 9.0 mm (0.354 in)
Front rotor
Brake disc thickness:
Standard: 25.0 mm (0.984 in)
Maximum refinishing limit: 23.0 mm (0.906 in)
Brake disc parallelism*: 0.015 mm (0.00059 in) max.
Rear rotor
Maximum refinishing limit: 7.5 mm (0.295 in)
Brake disc/drum parallelism*: 0.015 mm (0.00059 in) max
dave08902 is offline
The following 2 users liked this post by dave08902:
DUCRDX (06-15-2019), fcostantini (06-15-2019)
