Notices
2016 Acura RDX Technical Service Bulletins
Old 04-03-2015, 07:56 AM
Forum Contributor
EE4Life's Avatar
Received 1,112 Likes on 478 Posts
2016 Acura RDX Technical Service Bulletins:
TSB 15-019 - 2016 RDX: TQI and New Model Service Information
Applies To: 2016 RDX - All
http://www.urvi.net/forumfiles/SB/B15-019.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-019.PDF
TSB 15-020 - 2016 RDX: TQI of the Navigation System
Applies To: 2016 RDX - All with Navigation
http://www.urvi.net/forumfiles/SB/B15-020.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-020.PDF
TSB 15-023 - HomeLink System Has Weak or Limited Range
Applies To: 2013–16 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B15-023.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-023.PDF
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
Applies To: 2016 RDX - Advance, All with AcuraWatch Plus - ALL
http://www.urvi.net/forumfiles/SB/B15-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-027.PDF
TSB 15-051 - HFL Poor Sound Quality or Static
http://www.urvi.net/forumfiles/SB/B15-051.PDF
http://techinfo.honda.com/rjanisis/p...nu/B15-051.PDF
TSB 16-002 - Front Brake Noise and/or Front Brake Judder
This bulletin is replaced by S/B 17-049, Front Brake Noise and/or Front Brake Judder (2013–18 RDX).
Applies To: 2013-15 RDX - ALL - ALL
2016 RDX - 2WD - From VIN 5J8TB3...GL000001 thru 5J8TB3...GL012358
2016 RDX - AWD - From VIN 5J8TB4...GL000001 thru 5J8TB4...GL019272
http://www.urvi.net/forumfiles/SB/B16-002.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-002.PDF
TSB 16-015 - Audio Unit Displays Wrong, Blank, or Random Character Presets
Applies To: 2016 RDX - With Navigation - ALL
http://www.urvi.net/forumfiles/SB/B16-015.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-015.PDF
TSB 16-025 - Steering Wheel Noise When Driving
Applies To: 2016-17 RDX - 2WD - From VIN 5J8TB3...HL000001 to 5J8TB3...HL003353
2016-17 RDX - AWD - From VIN 5J8TB4...HL000001 to 5J8TB4...HL005430
http://www.urvi.net/forumfiles/SB/B16-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-025.PDF
TSB 16-043 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch
Applies To: 2013-17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B16-043.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-043.PDF
TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather
Applies To: 2013-16 RDX - ALL - ALL
2017 RDX - All 2WD - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL009835
2017 RDX - All 4WD - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL015307
http://www.urvi.net/forumfiles/SB/B16-059.PDF
http://techinfo.honda.com/rjanisis/p...nu/B16-059.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2016 RDX - Tech/Adv - ALL
2017 RDX - 2WD Tech/Adv - From VIN 5J8TB3...HL000001 thru 5J8TB3...HL006065
2017 RDX - AWD Tech/Adv - From VIN 5J8TB4...HL000001 thru 5J8TB4...HL009274
http://www.urvi.net/forumfiles/SB/B17-003.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-003.PDF
TSB 17-004 - Safety Recall: 2015–16 ILX and RDX Takata Driver’s Airbag Inflator
Applies To: 2015–16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-004.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-004.PDF
TSB 17-016 - Front Brake Noise (2016–17 RDX)
This bulletin is replaced by S/B 19-009, Front Brake Noise and/or Front Brake Judder.
http://www.urvi.net/forumfiles/SB/B17-016.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-016.PDF
TSB 17-017 - 2013-17 RDX: Judder from the Torque Converter Lock-Up Clutch (Snapshot Upload Required)
Applies To: 2013–17 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-017.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-017.PDF
TSB 17-018 - 2013–17 RDX: Judder from the Torque Converter Lock-Up Clutch After Software Update (Snapshot Upload Required)
http://www.urvi.net/forumfiles/SB/B17-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-018.PDF
TSB 17-049 - Brake Judder (2013–18 RDX)
This bulletin replaces S/B 16-002, Front Brake Noise and/or Front Brake Judder (2013-16 RDX).
http://www.urvi.net/forumfiles/SB/B17-049.PDF
http://techinfo.honda.com/rjanisis/p...nu/B17-049.PDF
TSB 18-021 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2016 ILX and 2016 RDX (Expires February 28, 2026)
Applies To: 2016 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-021.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-021.PDF
TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030)
Applies To: 2016-17 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-029.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-029.PDF
TSB 19-009 - Front Brake Noise and/or Front Brake Judder
This bulletin replaces S/B 17-016, Front Brake Noise (2016-17 RDX), and S/B 17-049, Brake Judder (2013–18 RDX).
Applies To: 2013-18 RDX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-009.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-009.PDF
TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized
Applies To: 2007-16 RDX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-018.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-018.PDF
Last edited by EE4Life; 03-28-2019 at 09:43 AM. Reason: Added TSB 19-009. TSBs 17-016 and 17-049 were revised
EE4Life is offline
The following 10 users liked this post by EE4Life:
5 Acuras (04-03-2015), Brown13 (06-28-2016), carbonTSEX (10-28-2016), Danny Boy (01-19-2016), EFItech (06-09-2015), giovane (05-23-2015), Harrison Chien (08-16-2016), NLRL (05-23-2015), Rocket_man (04-04-2015), wsw (03-29-2019)
Old 06-04-2015, 08:08 PM
Registered Member
I am looking at getting the 2016 Acura RDX, and i'm not super great with this car lingo... is this bad stuff? Or what does this all mean? Sorry
Jennifra is offline
Old 06-05-2015, 10:22 PM
Registered Member
The first two are targeted to the dealer and are procedures they should follow when preparing a RDX for delivery. The third one is a procedure to perform to increase the Homelink system's range and can be considered a relatively minor issue.
accord1999 is offline
Jennifra (06-06-2015)
Old 01-21-2016, 12:42 AM
Registered Member
carbonTSEX's Avatar
Thanks for keeping this updated.
carbonTSEX is offline
Old 02-01-2016, 05:10 AM
Registered Member
How do I "Check the iN VIN status for eligibility" as instructed on the bulletin?
Rolf65 is offline
Old 02-01-2016, 09:29 AM
Registered Member
blacktsxwagon's Avatar
This is a dealership tool and not applicable for the driver
blacktsxwagon is offline
Old 02-23-2016, 01:44 PM
Registered Member
Originally Posted by EE4Life View Post
TSB 16-002 was revised and the title was changed.
thanks. i dont have this symtoms but if this happens free brake rotors and pads!!
inmydream316 is offline
bvogel7475 (04-26-2016)
Old 02-25-2016, 10:55 PM
Registered Member
Just curious, how do we know if the dealer fixed these items on a recently purchased rdx? Are they required to or do we have to put out the TSB to them? I did a VIN check on the acura website and nothing comes up.
pinoyballah is offline
Old 02-26-2016, 08:33 AM
Registered Member
TSB is not recall. if you have any problem/issue relating to that TSB, they'll fix/replace that related parts. if they dont see any problem, they wont do it.
Old 03-06-2016, 08:51 PM
2014 RDX AWD Tech
Comfy's Avatar
Where do you get all these information from? Are you an Acura insider?
Comfy is offline
Old 03-07-2016, 09:06 AM
Registered Member
google
Old 04-26-2016, 05:52 PM
Registered Member
bvogel7475's Avatar
Thank you for posting the brake TSB. I know my rotors are shot on my 2013 RDX because I get significant shaking from time to time. I just figured I would have to eat the cost of getting them turned or completely replaced. Going to call my dealer right now to get this fixed asap.
bvogel7475 is offline
Old 04-29-2016, 07:05 PM
'16 FBP Advance FWD
kfhughes's Avatar
Thanks for posting that. I took my 2016 FWD in two weeks ago and had them check this but they said it the date stamp did not apply. I think they misinterpreted what "May 27, 2015 or later" meant since I check mine before taking it in and it's Sept 2015. My VIN is right in the middle of this group.
kfhughes is offline
Old 05-04-2016, 03:44 PM
Registered Member
I just had my front brakes pads and rotors replaced (i should have waited longer to get a free brake job but we couldnt stand the noise). Just curious why its been an issue since the '13 model. You would figure that would have made the change to production as soon as they found it or at least the following years model..
Old 05-16-2016, 01:11 PM
Registered Member
Brakes and Rotors replaced
The dealer had to replace the brakes and rotors on my brand new 2016 RDX, even though the vin wasn't part of the range earlier in the thread. They said it was a case by case basis and the range of vins in the bulletin isn't all inclusive.
el1668 is offline
Old 05-19-2016, 09:58 AM
Registered Member
kipsy's Avatar
hi el1668, what are the last five vin numbers ? I picked up mine end of april. how many miles before the noise occurs ?
kipsy is offline
Old 05-20-2016, 01:34 PM
Registered Member
30153. About 1000 miles in.
el1668 is offline
Old 05-20-2016, 04:32 PM
Registered Member
kipsy's Avatar
mines in the 22k range, with only 800 miles. its VIN is well past the TSB range.
kipsy is offline
Old 06-02-2016, 06:01 PM
2014 RDX AWD Tech
Comfy's Avatar
Is there any TSB for the rear shock / suspension noise?
Comfy is offline
Old 06-14-2016, 01:36 PM
Registered Member
Poor braking
My dealer replaced the rotor and break pads under the TSB. Now the breaking is very poor/slow and my car's stopping distance has been increased. Is it normal? I didn't have this issue when the car was new. Does the new car has breaks already bed in?
virtualH is offline
Old 06-14-2016, 01:54 PM
Registered Member
I am taking mine in tomorrow morning for rotor and brake pads.
I probably gonna have loaner since they said they need to diagnosis issue
Old 06-15-2016, 01:59 PM
Registered Member
i took my 2016 RDX AWD in today for front brake shaking issue.
i had this issue since around 5,000 mileage but didnt bother taking in because my laziness.
my mileage was reading around 23,xxx when i took her in today.
I explained briefly what issue was as well as showing my advisor TSB i printed out.
they replaced front rotors and pads.
i guess i saved my money and time for rotor and pad replacement in future.
Old 07-23-2016, 05:20 PM
Registered Member
Brown13's Avatar
Follow this link. Recall Information for Safety & Defects | Acura Owners Site
Brown13 is offline
Old 08-03-2016, 09:19 PM
Registered Member
alexderaven's Avatar
If 2016 was the redesign, why do most TSBs cover 2013-2016, and have the 2017 separate? Shouldn't it be mostly 2013-2015, and 2016-2017?
alexderaven is offline
Old 08-04-2016, 11:31 AM
Registered Member
Agreed. The 2016 is really more cosmetic than anything, but why did they not make running changes for things like the brakes and steering wheel creak? The car has been out since 2013, Acura should have resolved these issues by now.
chickdr is offline
Old 09-29-2016, 09:25 AM
Registered Member
Added new TSB 16-043 - Judder from the Torque Converter Lock-Up Clutch.
hmm i never felt this or didnt pay attention.. maybe i changed my ATF & transfer case fluid..
i hope they release software and i go in for update ecu
Old 10-21-2016, 06:54 AM
Registered Member
Added new TSB 16-059 - Pop or Clunk from the Rear Suspension in Cold Weather.
Thanks for the post.
Will have mine done with my next oil change in a month or so and right before winter.
The rear suspension has been loud even in summer but louder in cooler weather..
I complained about the noise when I got the RDX and was told they could find nothing wrong.
colt427 is offline
Old 10-26-2016, 12:55 PM
Registered Member
The key sentence is "The transmission fluid deteriorates quicker than expected when it is exposed to intermittent high heat loads under specific driving conditions."
how often do you change the ATF?
RDXMac is offline
Old 01-05-2017, 01:49 PM
Registered Member
I just had 16-043 done to my 2013 RDX (which i just bought used) - they did the triple flush and guess what... 1 mile later and the same judder/shudder/stutter around 1.5k RPM.
What does one do if the the Service Bulletin work does not work (other than bend over)?
arrrgh is offline
Old 01-05-2017, 03:21 PM
Registered Member
Skidoor's Avatar
You might consider the missionary position !
Is your warranty expired?
Skidoor is offline
Old 01-05-2017, 03:26 PM
Registered Member
Hey Skidoor - warranty is not expired. Acura dealer did the service free of charge - they could not have been nicer, etc. Will call them tomorrow to let them know it didn't work (and to ask them what their preferred position is).
it is a 2013 AWD with 36K
arrrgh is offline
Old 04-26-2017, 11:20 PM
Registered Member
Brakes kinda fixed...
Added new TSB 17-016 - Front Brake Noise (201617 RDX).
This new bulletin looks like it's the same thing, but covering more VINs right?
The last time I took my car in for the brake issue, they replaced the pads and I've only heard the brake noise a couple times.
el1668 is offline
Old 04-27-2017, 08:23 AM
Registered Member
We had the brakes replaced last year under the TSB. They have been great ever since.
chickdr is offline
Old 05-31-2018, 04:21 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 18-021 - Warranty Extension: Customer Support Program For Driver's Airbag Inflator for 2016 ILX and 2016 RDX (Expires February 28, 2026).
EE4Life is offline
Old 06-15-2018, 07:20 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 18-029 - Warranty Extension: Customer Support For Front Passenger's Airbag Inflator for 2016-17 RDX, 2014-17 RLX, and 2014, 2016-17 RLX Sport Hybrid (Expires June 30, 2030).
EE4Life is offline
Old 03-07-2019, 12:36 PM
Forum Contributor
EE4Life's Avatar
Added new TSB 19-018 - Safety Recall: Driver's Airbag Replacement Inflator Can Be Over-Pressurized.
EE4Life is offline
Old 03-28-2019, 08:54 AM
Forum Contributor
EE4Life's Avatar
Added new TSB 19-009 - Front Brake Noise and/or Front Brake Judder.
TSBs 17-016 and 17-049 were revised.
EE4Life is offline
rseb4agze
05-03-2016 07:41 AM
Zonian22
11-14-2015 01:20 PM
iRaw
Acura ILX Discussion
09-05-2015 12:10 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: 2016 Acura RDX Technical Service Bulletins
