Notices
2015 RDX front lift points
Old 06-19-2019, 01:45 PM
New Member
Hello trying to figure out front lift points (other than side ones for stands) in the back there is an obvious middle wedge but the front doesn’t appear to have this wedge - seems there are hooks near oil filter that should work given these are intended to tow and would be designed to support weight but wanted some advice before proceeding.
thoughts?
Mbarocker is offline
Old 06-19-2019, 01:46 PM
Received 5,938 Likes on 4,760 Posts
thoiboi is online now
Old 06-19-2019, 01:54 PM
New Member
Thanks but the section seems different on my car with lots of plastic - it also says 2007- present wouldn’t the 2015 be different since the frame was redesigned for taking impact? Seems like the plastic pieces would be crushed.
Old 06-19-2019, 04:46 PM
Registered Member
Here is the Factory manual on lift points. Hope this helps
File Type: pdf
dave08902 is offline
Old 06-19-2019, 11:18 PM
New Member
Thanks this helps.
qwxilvr
Fifth Generation TLX (2015+)
21
03-25-2016 11:31 PM
dapqam
Second Generation RL (2005-2012)
08-04-2015 06:34 PM
DwDrummer
02-17-2015 08:21 AM
sortudo7
First Generation TSX Discussion (2004-2008)
03-03-2010 08:41 PM
Zootking
Ramblings
17
09-17-2004 02:57 PM
Quick Reply: 2015 RDX front lift points
