2014 RDX Anybody Using a Yakima or Other Roof Box?
Hi All,
I'm wondering if anybody is using a Yakima RocketBox or Skybox with their RDX? I have an original Yakima RocketBox that I have used on my Accord, 325i and XTrail since 1994. I was hoping I could use it on my new 2014 RDX.... I just tried it today. It sort of fits, but not really. I can't get the box far enough forward, to clear the tailgate roof shade, so basically you can't open the tailgate. And it does sit too far back on the roof visually. So, time for a new box it seems. I'm considering a Yakima SkyBox 12 or 18. I need the length to carry down hill skis. Any information, photos or suggestions, greatly appreciated! |
Do you see any place underneath the front bumperto tie down the front of a canoe...I have my trailer hitch in the back which will work and of course the cross rails
I am running a Thule Boxter on mine with factory roof rails and thule cross bars.
Fits like a thumb in a bum - plenty of back and forth adjustment with the Thule clamp system. I get 2 sets od adults and 2 sets of kids DH skis in it now problems. Also no issues with lifting rear hatch with box in place. Only downside is the $$$, especially in Canada but I did a little cross border shopping and saved big $. |
Originally Posted by CharlieZ
(Post 14726629)
Originally Posted by yobbo
(Post 14726784)
Fits like a thumb in a bum - plenty of back and forth adjustment with the Thule clamp system. I get 2 sets od adults and 2 sets of kids DH skis in it now problems. Also no issues with lifting rear hatch with box in place. Only downside is the $$$, especially in Canada but I did a little cross border shopping and saved big $. Have any pictures with it on? |
Well, I think I'm going to go for a Yakima Skybox 12. It has the under cut back for the tail gate, and has nice adjustable mounts for placement. I'm planning on traveling to Edmonton a "Racks for Cars" to have a look see, and hope to come home with one.
http://www.rei.com/media/qq/107d1f18...69c19507d2.jpg |
Yobbo,
Would you mind posting a picture to show how the Thule crossbars look? Thanks. |
Box is not on the car at the moment and no plans until ski season. There is a picture of the box on a Lexus RX which looks similar in profile here:
http://www.clublexus.com/forums/rx-t...o-carrier.html |
LOL I like the post in that forum where the person does not like the roof box...
We all have our reasons :) |
I think I found the one... Skybox 12 in Onyx gloss black!
https://www.carid.com/images/yakima/.../8007195-2.jpg |
2 Attachment(s)
Okay, I stopped in at Racks for Cars in Edmonton. The Skybox 12 will not fit properly with out interfering with the tail gate.. So I went with the Skybox16 Pro Onyx instead. It has more cubic foot storage space, but is shorter and will hold a max length 185cm ski. This is good enough for me.
Here it is after install at a quintesential Canadian stop for lunch. Attachment 90819 I picked up a Yakima rack system for my friend's 2012 Civic as well. The Yakima dealer laughed and said he's never seen a rack in the box that is typically held by a rack to begin with :thumbsup: Attachment 90820 |
9 Attachment(s)
Here are some more pictures from the road trip to Edmonton to get the box.
The box just purchased and installed at Racks for cars in Edmonton Attachment 90828 The clearance is tight Attachment 90829 The Gloss Onyx finish is sweet! Attachment 90830 A stop at MEC (Mountain Equipment Co-op) for some other supplies :) Attachment 90831 The Trip Home, getting Fuel Attachment 90832 All Clean and shiny again Attachment 90833 Attachment 90834 Attachment 90835 Attachment 90836 |
Nice setup, are you noticing much difference in your gas mileage?
Thanks! I didn't track it coming back home from Edmonton. I did notice it was getting about 9 to 10L/100km which seems negligible. Impact. I'm sure it impacts mileage somewhat, but nothing that concerns me.
Stupid question: How do you load it or take it off? Do you use a ladder, stand in the door sill, stand on the tires? Silly question, but I always wondered.
Nice set up.
You may have mentioned it in one of your post, but does it interfere with the satelite reception?
Originally Posted by musty hustla
(Post 14753696)
In my other vehicles I stood in the door sills to clamp it down, however with the RDX I just step on the rear running board.
Originally Posted by terdonal
(Post 14753720)
Nice set up.
(Post 14753911)
It looks so good, I would put one on top of my car just even though I don't need one...lol. I noticed your front rails are about 6 inches forward of where mine are located. You said earlier that you can move them with a hex screw driver....is that difficult...is the nut easy to get to...I would like to know more about that or does the dealer need to do that?
3 Attachment(s)
(Post 14755048)
Adjusting the bars is a simple thing. What you need is a T30 Torx to adjust on the main rail and I found I needed a T25 Torx to adjust the crossbar width, as the rails span distance needs to be adjusted to allow free movement forward. It seems the width of the rails is not consistent along the span of the roof. I used a T30 in a socket to loosen and tighten the cross bars to adjust position along the rails Attachment 90837 A T25 is required to adjust the cross bar width to allow full range of movement along the rails. I used this low cost ratchet set I got at Canadian Tire as it is lower profile and gets into the bolts where my socket set would not. Attachment 90838 There are 2 Torx bolts per side on each rail Attachment 90839 Basically loosen all 2 x T30's on each side of the bar, then loosen the 4 x T25's, slide the crossbars where you want them on the rails, and tighten everything up. Hope that helps. |
ViperZ I can't thank you enough for going out of your way to clarify all of that for me....it will be such a great help when I put my canoe on the roof. I always say a picture is worth a thousand words and in this case definetly...thank you again for taking time to do this...C
No Probs, You're Welcome Charlie!
Hi, viperZ. Seems you come from saskatoon too! I am going to negotiate with Acura centre of Saskatoon next week. It seems there is price differences between mid provinces and BC or GTA (according to saskatoon salemen). There really does not have criterion available on this forums. Could you tell me your our the door deal price as a criterion? If you could do that, I could not be more appreciate for that.
I sent you a PM Dachvi...
Hi Viperz, did you look into other boxes? I want the Yakima Lopro but no get my RDX till next week and my roof rails till the week after
2 Attachment(s)
Originally Posted by cast
(Post 14733766)
Yobbo,
Would you mind posting a picture to show how the Thule crossbars look? Thanks. - Thule Boxster - Thule Cross bars - Andross Spec d 18" wheels (winter set) |
Are those dealer cross beams?
Does anyone have any complaints about noise running either a rocketbox pro 14 or a skybox pro 16? are they both made pretty well or is one better? Pretty big difference in price so i wonder...
Originally Posted by IndyRDXfan
(Post 15372615)
- Cheaper price, $200 for 2 extra cubic feet didn't seem like a bargain - shorter length, didn't want the box to over hang the front windshield catching the wind and interfering with the tailgate when open - 10lbs lighter, easier for me to put on by myself and a extra 10lbs I can put on the roof - Fits both vehicles perfectly I've had no issues with items getting dusty, dirty, or wet in over two years in traveling in all types of weather. No issues driving with the cruise control set to 80 mph and driving up to 90 mph to pass. Everything still works with no issues (locks, buttons, hinges). Very small dip in mpgs; but, the RDX and MDX already get crappy mpgs (especially at +80 mph). I only feel the roof box passing 18-wheelers and/or stiff cross winds. I don't hear or notice the roof box when on the vehicle. I do call ahead to check height restrictions if I need to park in a hotel garage. Skybox Pro 16 would come in handy if you need the extra length. |
Sorry to revive an old thread but this is the best post about OEM racks and cargo box :-)
I installed the rack and am trying to put on the cross bar. No matter how I adjust the torx screws, I can't get the front bar as front as ViperZ is doing. It still sits behind the door gap, about 3-4 inches behind these pictures. Anything I might be doing wrong? |
skywalker168 , sorry for asking: did you manage to install?
