2018 Acura NSX Technical Service Bulletins
Forum Contributor
Received 1,392 Likes
2018 Acura NSX Technical Service Bulletins:
TSB 17-051 - 2018 NSX: TQI Information
Applies To: 2018 NSX - ALL
http://www.urvi.net/forumfiles/SB/B17-051.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17-051.PDF
TSB 17-052 - 2018 NSX: TQI of the Navigation System
Applies To: 2018 NSX - All with Navigation
http://www.urvi.net/forumfiles/SB/B17-052.PDF
http://techinfo.honda.com/Rjanisis/p...nu/B17-052.PDF
TSB 18-050 - Safety Recall: 2017-18 NSX Fuel Tank, Product Update: 2017 NSX Thermostat
Applies To: 2017-18 NSX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B18-050.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-050.PDF
TSB 18-053 - Safety Recall: 2017-18 NSX Fuel Tank
http://www.urvi.net/forumfiles/SB/B18-053.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-053.PDF
TSB 18-064 - Creaking from the Driver's Dashboard Panel
Applies To: 2017-18 NSX - Vehicles with carbon fiber dashboard panel - From VIN 19UNC1...HY000001 thru 19UNC1...JY000096
http://www.urvi.net/forumfiles/SB/B18-064.PDF
http://techinfo.honda.com/rjanisis/p...nu/B18-064.PDF
TSB 19-013 - Climate Control Panel Buttons Sticking and/or Rattling
Applies To: 2017 NSX - ALL - ALL
2018 NSX - ALL - From VIN 19UNC1B..JY000001 thru 19UNC1B..JY000014
http://www.urvi.net/forumfiles/SB/B19-013.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-013.PDF
TSB 19-025 - 2017-18 NSX Wind Noise
2018 NSX - ALL - From VIN 19UNC1...JY000001 - 19UNC1...JY000094
http://www.urvi.net/forumfiles/SB/B19-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-025.PDF
TSB 19-069 - Product Update: NSX Warranty Information Booklet or CD
Applies To: 2017-19 NSX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-069.PDF
http://techinfo.honda.com/rjanisis/p...nu/B19-069.PDF
TSB 20-027 - Safety Recall: 2018-19 NSX Fuel Pump Motor
Applies To: 2018-19 NSX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B20-027.PDF
http://techinfo.honda.com/rjanisis/p...nu/B20-027.PDF
TSB 21-025 - Clicking from the Wheel Area
Applies To: 2017-21 NSX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B21-025.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-025.PDF
http://techinfo.honda.com/rjanisis/p...1-025 Ver2.PDF (Link works, but is wrong) Version 2
TSB 21-036 - Product Update: PGM-FI CPU Calibration ID May Not Output to a Generic Scan Tool
http://www.urvi.net/forumfiles/SB/B21-036.PDF
http://techinfo.honda.com/rjanisis/p...nu/B21-036.PDF
TSB 24-010 - Safety Recall: 2017–20 NSX Fuel Pump Motor
Applies To: 2017-20 NSX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B24-010.PDF
http://techinfo.honda.com/rjanisis/p...nu/B24-010.PDF
