2017 Acura NSX Technical Service Bulletins
2017 Acura NSX Technical Service Bulletins:
TSB 16-005 - 2017 NSX: TQI and New Model Service Information Applies To: 2017 NSX - ALL http://www.urvi.net/forumfiles/SB/B16-005.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-005.PDF TSB 16-006 - 2017 NSX: TQI of the Navigation System Applies To: 2017 NSX - ALL with Navigation http://www.urvi.net/forumfiles/SB/B16-006.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-006.PDF TSB 16-034 - 2017 NSX: Collision and Body Damage Repair Process Applies To: 2017 NSX Model Series - ALL http://www.urvi.net/forumfiles/SB/B16-034.PDF http://techinfo.honda.com/rjanisis/p...nu/B16-034.PDF TSB 17-035 - Audio Unit May Display “USB Not Responding.” Applies To: 2017 NSX - ALL - From VIN 19UNC1...HY000000 thru 19UNC1...HY000722 http://www.urvi.net/forumfiles/SB/B17-035.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-035.PDF TSB 17-048 - MIL Comes On with DTC P0128 Applies To: 2017 NSX - ALL - ALL http://www.urvi.net/forumfiles/SB/B17-048.PDF http://techinfo.honda.com/rjanisis/p...nu/B17-048.PDF TSB 18-049 - Safety Recall: High Mount Brake Light Applies To: 2017 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-049.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-049.PDF TSB 18-050 - Safety Recall: 2017-18 NSX Fuel Tank, Product Update: 2017 NSX Thermostat Applies To: 2017-18 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-050.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-050.PDF TSB 18-053 - Safety Recall: 2017-18 NSX Fuel Tank Applies To: 2017-18 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B18-053.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-053.PDF TSB 18-064 - Creaking from the Driver's Dashboard Panel Applies To: 2017-18 NSX - Vehicles with carbon fiber dashboard panel - From VIN 19UNC1...HY000001 thru 19UNC1...JY000096 http://www.urvi.net/forumfiles/SB/B18-064.PDF http://techinfo.honda.com/rjanisis/p...nu/B18-064.PDF TSB 19-010 - Chatter or Rattle Near the Door Tweeter Applies To: 2017 NSX - ALL - ALL http://www.urvi.net/forumfiles/SB/B19-010.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-010.PDF TSB 19-013 - Climate Control Panel Buttons Sticking and/or Rattling Applies To: 2017 NSX - ALL - ALL 2018 NSX - ALL - From VIN 19UNC1B..JY000001 thru 19UNC1B..JY000014 http://www.urvi.net/forumfiles/SB/B19-013.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-013.PDF TSB 19-025 - 2017-18 NSX Wind Noise Applies To: 2017 NSX - ALL - ALL 2018 NSX - ALL - From VIN 19UNC1...JY000001 - 19UNC1...JY000094 http://www.urvi.net/forumfiles/SB/B19-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-025.PDF TSB 19-069 - Product Update: NSX Warranty Information Booklet or CD Applies To: 2017-19 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B19-069.PDF http://techinfo.honda.com/rjanisis/p...nu/B19-069.PDF TSB 20-050 - Warranty Extension: 2017 NSX Keyless Start System Error with DTC B12C5 Applies To: 2017 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B20-050.PDF http://techinfo.honda.com/rjanisis/p...nu/B20-050.PDF TSB 21-025 - Clicking from the Wheel Area Applies To: 2017-21 NSX - ALL - ALL http://www.urvi.net/forumfiles/SB/B21-025.PDF http://techinfo.honda.com/rjanisis/p...nu/B21-025.PDF http://techinfo.honda.com/rjanisis/p...1-025 Ver2.PDF (Link works, but is wrong) Version 2 TSB 21-036 - Product Update: PGM-FI CPU Calibration ID May Not Output to a Generic Scan Tool Applies To: 2017-18 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B21-036.PDF http://techinfo.honda.com/rjanisis/p...nu/B21-036.PDF TSB 24-010 - Safety Recall: 2017–20 NSX Fuel Pump Motor Applies To: 2017-20 NSX - ALL - Check the iN VIN status for eligibility http://www.urvi.net/forumfiles/SB/B24-010.PDF http://techinfo.honda.com/rjanisis/p...nu/B24-010.PDF |
Added new TSB 24-010 - Safety Recall: 2017–20 NSX Fuel Pump Motor.
