What size are the fittings used in the clutch master and slave?
I'm ready to plumb the clutch hydraulics on the Odyssey this weekend. I'd have to replace the hard line from the master, the hose, and the hard line to the slave. Rather than replace it all with stock components, I'd like to get something like this.
http://www.allstarperformance.com/sp...s/pdf/1292.pdf
I'm wondering if it will fit, or if I can find something that will. I've found one for the CL, but I don't want to spend $80-$90 on it if I don't have to. If I knew what fittings I need, I could order one to fit.
The Honda fittings are 10mmx1.0 inverted flare. That hose you listed has a -3an on one side and a 3/16 inverted flare on the other. You should look for a hose with -3an on both sides and get 10MM-1.0 Japanese to -3 AN Steel Male Brake Adapter Connector Fitting
johnboy1313 (04-17-2017)
I ordered a 54" stainless clutch line for a 94-01 Integra or a 92-00 Civic. It fits perfectly. Thanks for the heads up.
Stainless Steel Clutch Line 92-00 Civic 94-01 Integra Black Complete Replacement | eBay
