What kind of tranny fluid to use??
just wondering what the best tranny fluid is to use when changing the fluid. its about that time for me to change my fluid... i have a 2001 3.2 CL-P
just want to hear what fluid some of you use. thanks!
Blown is Best
Amsoil is what I recommend. I've been using it for around 4 years and it seems to hold up better than Honda Z1. Amsoil ATF is one of the few synthetics that is says that it meets Z1 specs. Others have used Redline without a problem but the last time I looked, Redline still was not willing to say that their fluid met Honda Z1 specs. Both fluids are very good but if you're concerned about warranty issues, I would stick with either Honda Z1 or Amsoil synthetic ATF.
http://www.amsoil.com/StoreFront/atf.aspx
Blown is Best
Originally Posted by Bobbydoedoe
anyone here uses the GM synochmesh? the ppl at hondatech and s2ki loves that stuff
Some have gone to Syncromesh for their manual gearboxes. It's not a replacement fluid for autos.
Originally Posted by NightRider
I have heard good things about synchromesh, but with our ridiculous trannies....???
Received 1,080 Likes
Originally Posted by itsromy
what do you use Allout??
QUOTE=Allout]Amsoil is what I recommend. I've been using it for around 4 years and it seems to hold up better than Honda Z1. Amsoil ATF is one of the few synthetics that is says that it meets Z1 specs. Others have used Redline without a problem but the last time I looked, Redline still was not willing to say that their fluid met Honda Z1 specs. Both fluids are very good but if you're concerned about warranty issues, I would stick with either Honda Z1 or Amsoil synthetic ATF.
http://www.amsoil.com/StoreFront/atf.aspx[/QUOTE]
So far, as I wait for my Z1 to arrive, I am using Mobil1 synthetic ATF with LubeGard Black added to add the appropriate friction modifiers. The car shifts as smooth as silk! The LubeGard made a huge difference when I added it. Now, this being said, I am still switching to the Z1 when it arrives. The Mobil1 + LubeGard is more expensive anyway! However, I am going to use the less expensive Dexron III spec fluid for drain/fills in the future with the final fill being with the Z1. It's just silly to waste the expensive fluid on a drain/fill process.
same, I use AMsoil trans fluid and oil/filter in my 01 cl-s, 92 legend, 05 Ody.
you can mix it in if you want to, just drain the 3 qts and then add .
Blown is Best
I've run Amsoil in our 99 TL-P and I used to run Amsoil when I had the 2003 TL-S. Shifts are more consistent and not as suceptable to temperature - one of the benefits of Synthetic. Amsoil ATF and a tranny cooler make a big difference.
Blown is Best
does a tranny cooler void your warranty??? i have a bout 2.5 years left on my warranty... so, if it doesnt void it, i might seriously look into doing that.
Originally Posted by fender4
I have the comptech trans cooler on my cl-s. When the trans went out they didn't even ask about it, just gave me a new trans and hooked the cooler back up.
Originally Posted by TRILIGHT
Makes one wonder what the hell good it is then if the underlying tranny design is crap anyway. Wonder how long the new one will last ya. I'm sure they didn't redesign it.
You're a tranny engineer? Cool! What have they changed in the replacement units? Thanks!
Again sorry for mis leading about being a automotive transmission specialist, in my business we are paid to pretend to be experts in all fields of science.
Ah Ok so I'm curious what they replaced your tranny with? Was it a tranny with a new design/materials or was it just the same tranny but a new one with an oil jet kit installed? I'm just wondering if they actually put something better in or just the same old thing that has a very good chance of failing again in the future.
If the new one is a new design and/or materials and has a better chance of surviving, I might actually work to get it replaced before my 100k bumper-to-bumper warranty is up. Install a tranny cooler and keep the car for a good long time. However, if it is the same old thing, I may have to just dump the car before 100k because I don't want to take the risk. Thanks for the info!
I mostly drive hw 100 miles daily. But I have all the comptech stuff headers ect,, so I don't baby it all the time
Thanks again for the good info, fender4! I just ordered a case of ATF-Z1 and will be changing it out about every 20k as you do. I pretty much baby mine. No performance mods or racing. I do drive like a maniac on Houston freeways when people won't get out of my way though.
Ok, I just got my ATF-Z1 in today! Changed the fluid out to the Z1 and added the Smart Blend ATF Protectant from Life Automotive. All I can say is WOW!!!! I thought the change to the M1 with the HFM was good (over whatever was in the car before). This is unbelievable! I don't know if it is the Z1 by itself (a huge factor I'm sure!) or the addition of the Smart Blend but it is SO buttery smooth now! The car drives like it is brand new off the showroom floor! I will definitely not ever use anything else!
Originally Posted by TallyCL-S
Yeah the difference is significant when you change the old fluid w/ the new ATF-Z1.
Today I finally got my ATF-Z1 and the Smart Blend. It may be even better if I dump a third time and change it out. I know a lot of people recommend 3 times. All I know is that the Z1 with the Smart Blend right now is so far and away better than the Mobil1 + HFM! I bought a case of it so I'm good for a while. I don't want to waste it so I'll probably just drive it as is and begin my drain/fill process every 20,000 miles. I am just SO pleased with how well it runs now! Night and day difference!
How much of the Smart Blend ATF Protectant do you add?
Lubegard Red is much better than the SmartBlend equivalent, IMO. These products are merely LXE type products that will condition seals and improve oxidation resistance, somewhat.
You were much better off using M1 ATF and Lubegard HFM Supplement. The M1 is a much better fluid and will provide better resistance to heat and last longer under high-temp conditions.
It appears that Honda's TCM is not as sensitive and/or sophisticated as GM's, so shift times and feel will be greatly affected by fluid choice.
It's not uncommon to need to add 1.5oz/qt of Lubegard HFM Supplement to Dexron-III(H) or Dexron-VI to achieve identical shift "feel" as the genuine product. The smoother shifts though, as for their affect on longevity of the unit, is debateable.
Well, here's the thing. I'm sure some if it might have to do with the fact that I was sort of "flushing" the system. About a week ago, I added SeaFoam tranny stuff, drove around for about 20 miles, then dumped it all. Not knowing a lot about the tranny at the time, I loaded it up with Mobil1 ATF. Then I got worried since it wasn't the same as OEM. A couple of days later, I added LubeGard friction modifier in the black bottle which is supposed to convert regular Dexron III fluid into something more similar to OEM. It did make a big difference when I added the LubeGard! I could tell right away!
You added Seafoam (or tranny stuff, identical btw), drove for 20 miles, then drained and refilled your transmission ONCE with M1 ATF.
Then you added 10oz of Lubegard HFM Supplement.
And today, you did another single ATF drain/refill with ATF-Z1 and 10oz of SmartBlend protectant.
Dude, do you know wtf you're doing???
First, you still have a load of seafoam in your transmission. That stuff is very strong...and could damage the internal parts in the long-term, especially considering that Honda transmissions have a significantly smaller fluid volume in comparison to most units...so the dosage is much stronger if you had followed their directions.
Second, you have way too much friction modifier in the transmission. You overdosed the Lubegard HFM, now you added SmartBlend Red, which still has a slight FM capability.
Honda's TCM does not seem to adjust for shift times to the same extent as GM units, which is possibly why you are seeing significantly smoother shifts. With this much friction modifier in your transmission, you could be experiencing accelerated clutch wear.
You need to drain/fill this unit with Z1 to remove as much of this "soup" as possible. Then add 6 ounces of Lubegard Red if desired...
WTF am *I* doing? Do you really want me to post what you originally said before quickly deciding to change your story??
So don't pretend you know it all. Afterall, what you said originally was BS. As for the SeaFoam, it is the tranny version, not regular SeaFoam. There is not a "load" of it in my tranny, smartass. In addition to being drained with the original fluid, it was cleaned out even more by draining out the replacement M1 stuff. Which, as I mentioned before, was worse than the Z1 + SmartBlend.
Uhh...there's a reason why it changed as I realized it, lol. Nothing to do with being a smartass whatsoever...
You're missing the point here. Draining the unit only removes around 40% of the fluid, and after the second time...you would've still removed only 65% or so of the original "mix."
Unless of course...you mean by "dumping it all" to be draining/refilling three or more times, then I'm wrong...
SidhuSaaB
05-30-2020 12:40 AM
lanechanger
10-13-2015 10:56 AM
