VSA, ABS warning lights due to ABS PUMP???
Registered CL-er!
Well, I went to my mechanic to have my tranny fluid change and i asked him if he can scan the car for any codes related to ABS & VSA warning lights. After the scan, 6 codes popped up and it was all related to the ABS pump. He couldn't clear the codes because the system detected that the car wasn't leveled. Has anyone ecountered this? The only cause I found were related to wheels sensors. The lights go out and come back on sparatically.
Back in the summer, I replaced all rotors, pads, brake fluid and upgraded to ss lines. Can the ss lines be the cause? He advised me to drive the car for a few days and come back for another scan to see if the same codes reappear. Has anyone had this issue?
Those things are expensive for sure. You may need to take another look at your sensors on the wheels, but not seeing it, it is hard to tell. If you find yourself needing one, I have a good used one I stripped off a project car that works perfectly. Good Luck with it.
https://acurazine.com/forums/showthr...hlight=thinjim
Registered CL-er!
Originally Posted by proudacuraownr
I just had the pump replaced. It was under warranty thank God!!
Registered CL-er!
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
