tick tick tick
tick tick tick
At idle, my engine is ticking a little bit. Does this mean my valves need adjusted? I'm at 23K. I'll probably wait til the 30K service. Are there any other causes of this?
At your next oil change, have them flush the engine. You can also swithc to synthetic oil at this time if you haven't already done so. I had this problem on my old Ford Probe and after I flushed the engine the ticking wnet away...
The Creator
How very odd. (and scary)
That two people arrive at a very similar problem at the same exact time:
http://www.acura-cl.com/cgi-bin/ulti...c&f=1&t=007596
Yup. Shit always comes in pairs.... or something like that.
That's very similar to my problem, if not identical.
I just have to get it down to the dealer tomorrow and see if I can bother a tech for a minute to come listen to it.
-J
-J
Originally posted by soopa:
<STRONG>How very odd. (and scary)
http://www.acura-cl.com/cgi-bin/ulti...c&f=1&t=007596</STRONG>
Hey Jens....
Any ideas on what could cause this besides the valves need adjusting?
Originally posted by Jens Heydel:
<STRONG>Flush the engine??????? it would be better to have the dealership locate and correct the noise if in fact the noise is determined to be a problem.Jens</STRONG>
Gold, do you always use the same type of oil at your oil changes? If so, personally I'd try switching brands, especially to a synthetic (if you're not using it already) since they tend to keep the insides of the engines cleaner. And as autophile1 mentioned, I would try a quart of Motor Flush right before the next oil change also (if you change it yourself).
Originally posted by tinman:
<STRONG>
Gold, do you always use the same type of oil at your oil changes? If so, personally I'd try switching brands, especially to a synthetic (if you're not using it already) since they tend to keep the insides of the engines cleaner. And as autophile1 mentioned, I would try a quart of Motor Flush right before the next oil change also (if you change it yourself).</STRONG>
<STRONG>
All I know is my car isn't quiet like every other Honda/Acura car is, when it's idling.
Sounds like a beat up piece of garbage not a luxury car. It's embarassing.
*roll into my garage or up to a stoplight*
*clackity-clackity*
*clackity*
*clackity-clackity*
FACK, this thing sounds like a damn ten year old Buick.
-J
[ 07-01-2001: Message edited by: JRock ]
*clackity-clackity*
*clackity*
*clackity-clackity*
-J
Unfortuanately my best advice to you is to have the dealer take a look.I would advise you to demonstrate the noise so that both you and your dealer are on the same page.As for engine flushing....not me not in my car not ever no way no how ......nuff said?Jens
The Creator
My car is too noisy as fuck at idle from outside the car... but its not bad inside, only the CAI... but thats my fault! lol
But from outside... I have a loud ass ticking that sounds like its coming from rear wheel well. I know a bunch of people have said they had this too... maybe its same as you guys? Its really loud when pulling into a garage.
Most likely it is your injectors.
I had that noise in my accord and the dealer told me that it was the injectors ticking.
Bothered me tho, made my car sound like an old one
Originally posted by GoldTypeS:
<STRONG>
I switched to the ever so popular Mobil 1 synthetic at 7500 miles. First time I put it in I used the OEM filter. Changed the synthetic at 15k, thought it looked too dirty and changed it again at 20k. This time I used the Mobil 1 filter. Was planning on changing it every 5k, but the oil looks much better after 3k than it did the last time. We'll see...</STRONG>
<STRONG>
DiamondJoeQuimby
09-10-2015 11:40 AM
ghost_masterCL
07-04-2005 03:17 PM
