Teh CL's.... CLS6
Old 09-06-2014, 01:33 AM
  #41
AM To WDP In My Garage
acura_dipset_tl's Avatar
this thread is full of win. I cant wait for more updates. Great work o.p.
Old 09-06-2014, 08:02 AM
  #42
3.5 psi
gnuts's Avatar
Word on the street is the clutch is being broken in.....
Old 09-16-2014, 05:43 PM
  #43
teh CL's Avatar
Clutch is nearly broken in, been itching to dabble with Vtec ..
Car pulls really hard though, night and day difference coming from my 1st gen with the F20b..it's literally torque on tap
Pics coming soon & a head to head battle with the J35 vs Gnuts' SC J32..
The following 2 users liked this post by teh CL:
asianspec (09-16-2014), Marcelechka (09-16-2014)
Old 09-16-2014, 05:48 PM
  #44
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Old 09-16-2014, 07:24 PM
  #45
wickedpr1nce's Avatar
[/QUOTE]
cant wait to see that race...
Old 09-16-2014, 08:52 PM
  #46
3.5 psi
gnuts's Avatar
Oh yeah. Not sure if my exhaust will be done or not. We'll do it either way.
Marcelechka (09-18-2014)
Old 09-18-2014, 05:57 PM
  #47
teh CL's Avatar
Just went WOT for the first time...
Broke loose in 2nd gear when vtec engaged..
This car is gonna be fun
Old 09-18-2014, 07:14 PM
  #48
Damn 2nd gear is breaking loose..... sounds awesome man. Just tells me your car is gonna be beastly
Old 09-19-2014, 01:31 AM
  #49
Membistered Regember
jaeravenal's Avatar
SO JELLY OF YOUR COME UP
Old 09-22-2014, 11:47 AM
  #50
teh CL's Avatar
Turn the car on this morning & once she warmed up the idle started bouncing then went away, IACV is brand new.. Check the CEL & got P1297 - electrical load detector..
From some quick searching it's in the fuse box under the hood & the whole fuse box has to be replaced..
Old 09-22-2014, 01:02 PM
  #51
Majofo's Avatar
Could be several issues.. are you using the same fusebank from the J30/32?
Old 09-22-2014, 01:26 PM
  #52
3.5 psi
gnuts's Avatar
shit! you've had a sting of bad luck.
Old 09-22-2014, 04:44 PM
  #53
teh CL's Avatar
^ she does have 300k, stuff is bound to go..
Yes, it's the stock 6 speed fuse box..
What else could it be?
Old 09-22-2014, 05:42 PM
  #54
Majofo's Avatar
I'd cross check the main fuse values for the J35 and the main fuse values in the fusebank. If they're appropriately rated, check idle related fuses (IACV, MAP, MAF, etc). Does the J35 have a maf and map sensor as well? Assuming everything is appropriately rated and wired, I'd then back track the connections to make sure the connection and wiring from each are fine. If everything checks out, I'd make sure there's no manifold / vacuum leak somewhere.
Old 09-22-2014, 05:44 PM
  #55
Majofo's Avatar
Basically the PCM is adjusting the load because of the fault which is why it's bouncing. If you're certain that it happens when it's warm only.. you might start with the intake side from manifold back. Then check the fuse ratings and intake side wiring / connections.
Old 09-22-2014, 06:12 PM
  #56
teh CL's Avatar
Between the j35 and the j32, there was only one sensor that was different (except for the 6spd sensors) & it was the one on top of the TB (MAF?).. I depinned the wires from the J32 plug & plugged them into the J35 sensor without a connector if that makes sense.
I just got home from work & the idle didn't bounce at all once the car warmed up or on the way home at a light.
I'll look into the MDX main fuse values
Old 10-05-2014, 05:37 PM
  #57
teh CL's Avatar
Electrical load detector CEL is gone. Replaced the serpentine belt/tensioner last week & it hasn't been back yet. Idle still bounces between 1000-1200 rpm probably once a day but there's no CEL..
From one thing to another.. Was out of town last weekend & my axle decided to take a shit on me, so I got it replaced along with the lower ball joint on the passenger side at a local shop. Everything was great till Friday night when I started hearing a creaking sound (aka dungeon door opening) by taking off from a stop & slowing down to stop.
Jacked the car up to make sure everything was good & it all checked out. I've searched different threads but haven't found a definite answer, any insight would be appreciated..
Old 10-06-2014, 03:50 PM
  #58
Scottyknows007's Avatar
Does it do it over ruff/ uneven surfaces? or just on acceleration and stops?
Old 10-06-2014, 05:08 PM
  #59
teh CL's Avatar
Just accel/stop.. Sounds sketch to say the least
Thinking it could be the spring/shock when the weight of the car is being shifted
Old 10-06-2014, 08:30 PM
  #60
Yea it could deff be the springs or shocks.. my car eats up upper ball joints like its its job. It would make a similar noise on acceleration and deceleration, to start but now on any shifting of weight on the front end
Old 10-06-2014, 08:42 PM
  #61
teh CL's Avatar
We'll see how it plays out..
It's actually real convienient that I'm grabbing some coilovers this week which hopefully will correct the problem but they need a set of replacement springs before they go on ...
97BlackAckCL (10-07-2014)
Old 10-21-2014, 12:56 AM
  #62
Adam Kovach's Avatar
no clearance issues with the j35a3 block and j32a2 heads? I've read through an abundance of posts that stated that the j35a3 pistons wouldn't clear the j32a2 valves.
Old 10-21-2014, 08:26 AM
  #63
3.5 psi
gnuts's Avatar
he used a full J35A3 engine. However i've read information that says they will clear. The J35A3 heads are nearly identical to the J32A2. I think the J32A2 has a 1mm bigger exhaust valve and different cams. So you could just use a J35A3 and put in different cams.
Old 10-21-2014, 02:04 PM
  #64
teh CL's Avatar
Just swap the J35 motor, no need to be disassembling 2 motors..
Old 11-04-2014, 11:13 PM
  #65
teh CL's Avatar
Just hit 5000km since I did the swap & loving the car more and more each day..
In the last few weeks she's had some gremlins though, with a fluctuating cluster/idle which ended up being solved by redoing a couple grounds.
Tip of the day: always start with simple shit when something goes wrong
Finally managed to get my hands on the OEM rims from the previous owner which took almost 2 months.. .. So the brutal rims that came with the car are getting tossed & the OEMs are getting a fresh pair of snow tires this weekend since the winter season is upon us..
Old 11-05-2014, 02:17 AM
  #66
Majofo's Avatar
Old 11-05-2014, 04:28 AM
  #67
bigdaddyKA8's Avatar
Nice work indeed, good to know theres some simple options out there once I'm done toying with my blower set up too. I wonder what numbers you'd put up with a blower on it???
Old 11-05-2014, 05:44 AM
  #68
CLtotheTL32's Avatar
Received 9,495 Likes on 6,167 Posts
Moar pics!
Old 11-05-2014, 08:28 AM
  #69
3.5 psi
gnuts's Avatar
we should meet up this weekend. i have to get you those parts. I also have a bit of intake piping you might be able to use.
You don't have a GoPro do you?
Old 11-05-2014, 09:13 AM
  #70
teh CL's Avatar
I would love to find out, maybe we can sweet talk Gnuts to let me "borrow" his blower for a dyno run..
Moar pics!
This weekend hopefully..
We can set something up for Sunday & I'll try to find one, if not I'll buy one then return it...
Old 11-05-2014, 09:26 AM
  #71
3.5 psi
gnuts's Avatar
with a 3.5 i think you'd have to run the HBP to flow enough air to make it move. I still have the HBP sitting around....taunting me. I won't put it on without some kind of cooling. I'm leaning towards a front mount intercooler for its simplicity.
A video would be great. I've tried with my phone but it's too hard (and dangerous).
Old 11-05-2014, 10:04 AM
  #72
teh CL's Avatar
A front mount would be soo damn sick & what size is that intake piping? I'm thinking of making a tapered intake pipe, from 4"- 3.75 - 3.5 - 3.0 - 2.75 (size of the 70mm TB) with a velocity stack..
Idea is to increase the intake air speed with the tapered pipe (ie. ITB runners) even more than just having a velocity stack. Never seen one before so I'm really curious how it would turn out
Old 11-05-2014, 02:30 PM
  #73
3.5 psi
gnuts's Avatar
it's 3.5" plastic. its from an Airaid U-build-it intake.
Old 11-05-2014, 02:51 PM
  #74
mattcl-s's Avatar
wow super nice whip! wish I had the knowledge, time and tools to mess around my cl... good job!
Old 12-14-2014, 07:19 PM
  #75
teh CL's Avatar
Here are some random iphone pics, don't mind the dusty front bumper..
Coming soon..
Old 12-14-2014, 07:47 PM
  #76
3.5 psi
gnuts's Avatar
Oh yeah, nice rack.
Old 12-14-2014, 08:26 PM
  #77
Majofo's Avatar
looks great!
Old 12-14-2014, 08:27 PM
  #78
Majofo's Avatar
Is the driver side of the hood near the windshield misaligned a bit?
Old 12-15-2014, 08:34 AM
  #79
3.5 psi
gnuts's Avatar
I think he has the MDX spacer on so the hood is propped up a bit.
Old 12-15-2014, 11:06 AM
  #80
Majofo's Avatar
Ah makes sense.. Good to vent hot air too..
Quick Reply: Teh CL's.... CLS6
