Pulley information
Pulley information
Someone posted a replay to a thread suggesting to add a light weight pulley to help give more useful power, but can't find the thread! If anyone knows that link and/or the link to the ebay listing I would greatly appreciate it!! Also, has anyone installed a crank pulley? There isn't much room there, how to you get into the space to change it!!! Thanks
666 Speed
1 Post
Pull off the pass. side wheel and its right there.
You can either the Option racing pulley (cheap and effective) or the Unorthodox Racing pulley (expensive and effective also)
Your choice. Both can be found on ebay.
This is a great mod that you'll feel every time you run thru the gears. The bolt that holds it on is REALLY tight, but a 3/4" impact gun or a really long breaker bar will get it off.
Former Sponsor
http://store.excelerateperformance.c.../i-220257.aspx
I finally got my option pulley in and want to put it on today. Has anyone put one of these on before? Is it as easy at is looks? Loosen the belt, take it off, use the big breaker bar to get the center bolt off. I'm guessing you need to use a pulley to pull it off? Then work the pulley on, install the bolt, reinstall the belt, tighten the belt and rock and roll! Am I missing anything????? Thanks
emailnatec
29
09-28-2018 04:27 PM
AmplifiedDetails
09-24-2015 02:55 PM
