Proper way to seafoam?
Old 01-16-2012, 01:24 PM
P.
VIPCLS's Avatar
What is the proper way to seafoam the CLS? I know you can just pour the bottle in the tank, but have overseen other threads that have a different method. Who on here has seafoamed, and how?
Old 01-16-2012, 01:51 PM
3.5 psi
gnuts's Avatar
i think there's a DIY here or on the 2nd Gen TL side. I sucked a bit in through the intake and a bit in the tank too.
Old 01-16-2012, 02:26 PM
99 TLS6 08 TL
timberland73's Avatar
https://acurazine.com/forums/showpos...52#post2033721
Old 01-16-2012, 10:12 PM
P.
VIPCLS's Avatar
Thanks, but have already seen that link. Dont know about that sounds sketchy, but I bet it works properly if done properly. I mean can you harm the engine by overdoing one of the steps? Or should I just add it to my gas tank? What is the advantage with the other method?
Old 01-16-2012, 11:49 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
the way i did it on my car was remove the vac line going in to the front of the TB that has that lil metal bar that goes around the tb. plug the line. take a hose that fit onto that orfice and then that's the hose that will suck the seafoam into the engine as it's running.
put seafoam in a clear container so u can see how much u suck up.
u want to sucka lil at first then a lot at the end to choke the motor out.. then u leave it in there for 2-5 mins.. the longer the better they SAY. but it becomes harder to start the car the longer u leave that stuff in there.
when u start the car up u will see the cloud of smoke and ppl will think ur car caught fire most likely... it's hilarious
Old 01-17-2012, 12:54 AM
Unregistered Member
Karanx7's Avatar
There's nothing sketchy about that DIY. In fact, it's spot on. There are plenty of wrong ways to do it, but that DIY is perfect.
Old 01-17-2012, 09:31 AM
99 TLS6 08 TL
Agreed. That's how I did mine.
pwehmeier (01-18-2012)
Old 01-17-2012, 11:12 AM
1sickaccord's Avatar
theres nothing to it .. i take 3 clear plastic cups and pour even amount into each one
then pour the 1 cup into the gas tank
1 cup into the oil
and 1 cup into the vacume line you pull off your brake booster that goes into your manifold
(but here you have to pour slowly so car doesnt shut down)
then once you do that turn car off and wait 15 minutes .. aka smoke a cigarette and have a beer .. or whatever it is you do lol
turn car on and be prepared for white smoke like crazy then rev and drive around until stops smoking
and change the oil within next 100 miles
Old 01-17-2012, 03:14 PM
P.
VIPCLS's Avatar
Allright, I am going to use the DIY. It says the pics are high quality on the DIY, but when you click for the larger image it is the same size jus sayin. I am pretty sure I can figure the proper induction point on the engine, so it really doesn't matter about the pics. Thanks.
Old 01-17-2012, 07:37 PM
Unregistered Member
Karanx7's Avatar
Actually, it is correctly coded to open a new page with the larger image. If your computer is not able to do so, it's a little sketchy jus sayin.
Old 01-17-2012, 10:26 PM
P.
VIPCLS's Avatar
Haha funny little guy are you?! I figured it out dickhead, I had to click on the image after you click on the image on my computer. And yes the DIY is correct, I just didn't read it well before I posted that comment it's not "sketchy" folks.
Old 01-18-2012, 07:48 AM
^ really u took offence to him calling ur comp sketchy? really
buddy is trying to enlighten u and u shit on him? how is he supposed to kno it's not ur computer BUT THE ACTUAL users fault that the pics wouldn't open?
he WAS even giving u the benefit of the doubt that it wasn't ur fault, but ur computers.
u should really think before u write it in stone.
Old 01-18-2012, 03:15 PM
P.
VIPCLS's Avatar
Your right, my bad karanx7. I have just been exposed to too many negative responses on alot of threads on here, and take things too seriously sometimes.
acuratl26
04-23-2020 07:30 PM
ExcelerateRep
10-14-2015 08:20 AM
DementiaPhuro
09-29-2015 05:31 PM
kingbharj
09-25-2015 07:25 PM
Quick Reply: Proper way to seafoam?
