Problems: LIPPSTUH'S JERKING
Old 08-01-2008, 01:20 PM
Unregistered user
LIPPSTUH's Avatar
Alright, so far I have replaced spark plugs and primary o2 sensor. Still have CEL and still have the symptoms
I had a feeling that the o2 sensor wouldn't cause this problem, but at the time it was the only code that came up.
Symptoms: From time to time (sometimes its frequent sometimes not) when I accelerate (esp slower acceleration) i will get a cut off gas (or so it feels like). I would keep a steady foot then it doesn't keep accelerating. So i keep pressing the gas pedal down. then suddenly it will jerk a bit because it'll start accelerating all of a sudden. so there's a lag. sometimes when this happens, i will let go of gas and gas it again and it doesn't create that lag.
and no its not a clutch related problem.
i THINK its ignition coils because a few people had this problem and said that's what fixed it, when I replaced spark plugs i didn't notice anything wrong. but whatever. what do you guys think?
Old 08-01-2008, 01:56 PM
DaInFaMMuS1's Avatar
My H23vtec does the same thing, but it's misfiring. I have a faulty distributor and a bad headgasket
Old 08-01-2008, 02:11 PM
Ralphie917's Avatar
I was going to post about about this sooner or later - but i also, as of late, have been noticing sort of the same thing --- only mines sort of a very slight, but very noticable hesitation...
Same symptoms, have only noticed it going slower speeds/lower RPMs - definately not clutch and definately not driver induced...
My throttle only cuts off for a split second then resumes as normal, doesnt stay "cut off" for longer than that.
Have noticed it 3 times in the last month and a half or so.
OG 3.x^7 rawr
SPoolinspOON's Avatar
possible bad TPS?
Old 08-01-2008, 02:13 PM
OG 3.x^7 rawr
mine has been doing the same...I did notice on mine that it occuring in the morning. I'll cruise at about 30mph and then there is a slight jerk, like a fuel cut off, and then resume...
Old 08-01-2008, 02:20 PM
fuzzy02CLS's Avatar
That is actually normal. All 3 of my CL's have done it from time to time. Only at low rpm & only for a split 2nd. No hard reason for it. Some think it's a low voltage or sudden power drop problem to run something on the car.
Old 08-01-2008, 02:44 PM
Unregistered user
LIPPSTUH's Avatar
damn now im not sure if its the ignition coils or not... i guess i'll have to buy a obd-II reader this weekend...
guessing on the fix is never ever fun for me or my wallet.
Old 08-01-2008, 03:25 PM
why not go to autozone where they let u use their obd2 reader for free in the parking lot?
Old 08-01-2008, 03:32 PM
Unregistered user
LIPPSTUH's Avatar
they don't do that anymoreeee
Old 08-01-2008, 04:37 PM
MP90 uninstalled
jproy's Avatar
all of them here do but that doesnt help you does it.
I have noticed the jerk too. I get it sometimes after starting the car and driving between 30-40mph at a constant throttle input. It is a drop in power for about .3 seconds and then everything is normal for the rest of the drive. It usually happens only within the first 5 miles of driving. I really noticed it after I put the blower on but it is not on now and it has done it without it. Jim
Old 08-01-2008, 05:07 PM
Unregistered user
LIPPSTUH's Avatar
mine can last for 1-3 seconds... yeah.. depends if i step on it or let it go like explained in the first post....
Old 08-01-2008, 09:30 PM
aznboi2424's Avatar
If you have a AAMCO near by, they will read your CEL for free. I just saw a commercial on it. They also have AC check for free too. might as well since your down there anyways.
Old 08-01-2008, 10:34 PM
666 Speed
artbran's Avatar
Mine does it. It got worse when I changed my o2 sensors. turned out I had a bad first sensor...
Old 08-01-2008, 11:40 PM
Unregistered user
LIPPSTUH's Avatar
i just changed mine.. same shit.
Old 08-02-2008, 02:30 AM
Blown is Best
Allout's Avatar
Have you checked for vacume leaks?
Old 08-02-2008, 06:33 PM
Unregistered user
LIPPSTUH's Avatar
not yet.
i ran the obd-II and it STILL says that I have p0132
O2 Oxygen Sensor Circuit High Voltage (Bank1, Sensor1)
I just changed it 2 weeks ago with a new one. bank 1 = the one on the cat correct? its acting exactly the same right after I changed it. There is no way that both can be bad. I only have 48k on the car.
Old 08-03-2008, 11:45 AM
OG 3.x^7 rawr
Bank 1 is the first oxygen sensor. Maybe you got a DOA O2 sensor? What brand was the O2 sensor?
Old 08-04-2008, 01:38 AM
Unregistered user
LIPPSTUH's Avatar
denso, i'm going to switch the other one as well... give me a few days. i'm PRETTY SURE i switched the wrong one =X
feel like such a
Old 08-04-2008, 01:06 PM
EL19's Avatar
check for header cracks. Ive seen it happening to a few ppl due to a crack in the welds. When off the gas the leaks sucks in air and mess with the o2 reading. Just a precaution tho.
Old 08-23-2011, 01:38 PM
LiquidCLs6's Avatar
sorry to bring back an old thread, but did you ever figure out what the problem was?? I've been having the same symptoms for a couple weeks now, and finally the car threw a P0132 code... I have searched a couple threads with similar problems but as far as I know no one had any luck with a solution.
Old 08-23-2011, 07:06 PM
StreetKA's Avatar
i believe its a bad o2 sensor but make sure you wont get Bosch just a Denso or other brand our ECU doesnt like Bosch sensors
Old 08-19-2019, 08:42 PM
jthiessens's Avatar
This is what I got driving from NC to Boston last week and I am really happy with the mileage I got. This was also sitting on the interstate for an hour dead stop and driving around in Boston.
Mike Pilipenko
03-26-2024 09:21 PM
NwTSXmt
3G MDX (2014-2020)
40
12-01-2015 12:01 PM
DidiBob
4G TL Problems & Fixes
09-23-2015 08:14 PM
DwDrummer
5G TLX Problems & Fixes
09-14-2015 08:20 PM
wendtdc13
1G RDX Problems & Fixes
08-30-2015 06:39 PM
Quick Reply: Problems: LIPPSTUH'S JERKING
