Pressure Switches 01 CL-S
Lately I've been reading about the 3rd and 4th gear pressure switch replacement, but I tried doing some research and couldn't find which one is which, I attached some photos, if anyone can help identify them. Thanks!
The case is cast with the corresponding gear switch ID number. You can see it in your first pic just below the wire connector... The small rectangle cast into the case is the gear switch ID number. One for each gear switch.
