pressure switch differences
Hello, have a 2001 CL-S with automatic trans 16000 km's on it, Was changing out the 3rd gear transmission pressure switch as blinking D5 light was coded as "bad switch" .
I ordered the switch correct number " 28600-P7Z-003 " and was sent a "28610-RKE-004 " this was from the Honda dealer. The colour is the same/black and connector the same but the body is not a "stepped" design but flat design and the "male" end with the threads is about 1/8 shorter and has no washer like the switch that I removed.
Just want to know if I should use this and add my old washer or leave it off ?
thanks :R.J
thanks :R.J
https://www.oemacuraparts.com/v-2001...ensor-solenoid
According to this parts diagram, neither of those work for your car
28610-RKE-004 should be for MDX, TL, RL's, : https://www.oemacuraparts.com/oem-pa...ya-28610rke004
There is a
https://www.oemacuraparts.com/oem-pa...dXRvbWF0aWM%3D
28600-P7Z-013 replaces 28600-P7Z-003
There is a
28600-RKE-004
that would fit your CL:https://www.oemacuraparts.com/oem-pa...dXRvbWF0aWM%3D
My car wouldn't start in park tonight but did start in neutral. It never did this before. I think it is this switch. The interesting thing is that I had the car sprayed with rustproofing spray earlier in the day. I wonder of the switch housing is no longer sealed and some of the rustproofing oil got into it. I am calling the local Honda dealer in the morning to see if they have the switch in stock as the car is already scheduled to go to my local shop for a ton of other work tomorrow. Timing belt, pullies, tensioner, water pump, passenger side radiator fan replacement, diff fluid replacement and a drain and refill on the ATF. Might as well do this too while it is on the lift. If not, I will have to order it and do it myself.
spydercatt
01-28-2013 06:19 PM
