P0336 Please Help
Old 09-21-2009, 12:48 PM
2003 CL-S 6MT
Total2f's Avatar
P0336 Please Help
So here is the story. My car has some clicking noise from the engine bay and this may be related or not to my current problem. But driving one day for about 30min my car was fine I had just upgraded the brakes and was working on braking them in. I stopped driving the car for about 1.5 hours and went to start it . . . it started but then died tried again nothing, so I had it towed, the next day it started and drove fine until it warmed up then it would cut out/ not rev after 2k rpm, it also threw the code P0336 Crank Position Sensor A. I replaced the sensor with one from my old motor which is the exact same motor J32A2 and it did the same thing. Any ideas?
Old 09-21-2009, 01:30 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
when that happend to my other car it was seriously messed up internally. You changed the sensor and the same error comes up would most likely mean it's your crank that messed.
My crankshaft was bent when that code came up for me and it was a fordged crankshaft... that was a Probe tho
Old 09-21-2009, 03:15 PM
2003 CL-S 6MT
Total2f's Avatar
I seriously doubt its the crank, I don't think it would run at all if it was that. It goes through the whole rpm range when its cold but was soon as it warms up its almost like it loses fuel after 2k. Idk i just want my car back.
teh CL (02-13-2015)
Old 09-21-2009, 05:10 PM
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,398 Likes on 4,941 Posts
Maybe skipped timing?
Old 09-22-2009, 09:53 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Id try replacing the ckp sensor with a new one and check the wiring. If it still does it it may be the ECU.
And for your ticking noise, is/was it coming from the drivers side only heard when the car was idling?
Old 09-22-2009, 10:21 AM
3.5 psi
gnuts's Avatar
^ ya, ticking makes me think of the purge solenoid valve. It's a little guy at the back of the engine bay (drivers side). If you put your finger on it, you can feel the tick.
Old 09-22-2009, 06:40 PM
2003 CL-S 6MT
Total2f's Avatar
Yeah I can't quite pin-point the ticking but I'll check the purge solenoid valve thanks. The wiring was checked on the ckp sensor and it is supposedly all fine. The mechanic seems to think its a sensor on the bell housing.
Old 09-23-2009, 10:12 AM
2003 CL-S 6MT
Total2f's Avatar
bump
Old 09-24-2009, 11:49 PM
TarzanCLS's Avatar
isnt it an interference motor? skipped timing would seriously bend valves and have a ridiculous noise..
Old 09-26-2009, 12:22 PM
2003 CL-S 6MT
Total2f's Avatar
Mechanic found a wire that was supposedly shorting out so they replaced that and the sensor on the bell housing and it runs fine now. . . idk this was defiantly a weird malfunction. The ticking is the purge valve solenoid so I guess the next step is to just replace that right??
Old 09-27-2009, 02:41 AM
civicdrivr's Avatar
Skipping one tooth wont neccessarily cause bent valves. Honda motors are interference motors, but the clearances are that tight.
Old 07-04-2011, 09:34 AM
AcuraGman's Avatar
Total2f, what was your problem with your car when it threw Po366? I have a 03 6mt and I just changed the timimg belt and it threw that code.
Old 02-13-2015, 07:14 PM
JDM CLS6's Avatar
I got that code today. I'm hoping its just a bad Crank Position Sensor. I did an engine swap in October as well as new Luk clutch kit. I used the sensor from the old 210k motor so I'm assuming it finally gave up? Also, why did advance auto just quote me $319 for a crank sensor but the dealer is only $150? Makes no sense.
joshTL
01-08-2015 08:14 PM
driveway mechanic
1G CL Problems & Fixes
12-30-2013 02:07 PM
ArTL-S
06-04-2011 01:04 AM
1hotcls6
2G CL Problems & Fixes
57
07-11-2009 12:59 PM
Quick Reply: P0336 Please Help
