Onstar Antenna & Mirror
Trust Me I'm Better!
Is it possible to install the mirror and antenna (for looks only) on a CL?
If someone was brave enough could it be done. Is the mirror a direct swap? Theparts would be out of a 03' CL btw.
Received 2,328 Likes
It can be done.
Care to elaborate Ken? How hard would:
1. Drilling a hole on roof and postioning the antenna in the exact OEM spot.
2. Taking out headliner.
3. Swapping out mirrors.
I'm doing this because I've always like the way it looked. The Onstar in those cars don't work anyway. They are dead. There would be no cable to hook up to it. Would the auto dim feature still work using that rear veiw mirror?
Whats up with RDX owners?
Are you doing this so your insurance agent can see the car and you can get a discount for having onstar?
2) Easy, better make sure you know what you're doing though. Be careful with your hands, use clean gloves to keep dirt off.
3) Mirror is easy too, just need to figure out the wiring.
You're doing this strictly for appearance? Sounds like a lot of work, you might as well ditch the Onstar 'look' and just install bluetooth using the Onstar mirror buttons and stock stereo setup.
Thanks everyone for your input and answers. I don't recall anyone ever doing it as far as the antenna was concerned. BTW Ken, I did the navi conversion back in Nov. 07' with the A/C controls and voice prompts so this doesn't seem too difficult but a little scary about the roof part. As always the the prep work will be the key. We'll see, maybe sometime after the New Year.
I Wanna Beer
You can just get stick on roof antenna fins if you're just doing it for looks.
http://cgi.ebay.com/BMW-Type-Shark-R...item588450e423
http://cgi.ebay.com/ebaymotors/MERCE...ht_1407wt_1167
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
If you're doing it just for looks, no need to cut a hole in your roof. Just get an antenna and the mirror should swap right on
Can any of the CL owners that have it provide the measurements for the 2 red lines. Up from the back glass and then from the side. I believe that the back glass has a line down the middle of it that I could actually use to line the antenna up with which will make that very easy to use as my guide. Can you confirm this. Also where is the DIY pinout to install the mirror? Thanks to whoever responds.
If no one can give you exact measurements, I can say that it appears to be about 1.5" off the glass, right in the middle of the roof.
x3 on the aftermarket stick on antennas if your just looking for the look. Your drilling a hole into the roof to put a nonfunctional antenna there, might as well just put a stick on type.
theres no DIY. just take the mirror off, looks for the colored wires and match them out and splice away. Its probably 2 wires, power and ground, which is black.
As far as the mirror, is it a direct swap (other than wiring) or do I have to buy the plastic mounting pieces?
Chamorro
https://acurazine.com/forums/2g-cl-2001-2003-50/rearview-mirror-replacement-diy-724233/
As for getting the wires to match up that will take a little trial and error. You'll have to get a wiring diagram for the new mirror with the onstar so you can figure out which are just power wires so you can get the dim feature to work right. GL!
I think you guys are wrong about the mirror. The way the Onstar mirror attaches to the windshield looks to have different hardware than the normal CL Type-S mirror. The original metal mount bracket that's glued on the windshield is different?
AFAIK the mirror isnt glued to the window. Its mounted to the roof. The plastic piece going up the window is just a cover for wiring.
I could be very wrong though
true but I think 5thgen is saying that the metal bracket (thats attached to the windshied) where the mirror is supposed to be attached to is different from the regular mirrors and the 03 mirrors. if they are then im not sure.
i havent heard many that have swapped mirrors on here. best thing i can think of is to try to compare the old mirror and new mirror's metal bracket attachment points on the mirror itself. If they are different then they should look different
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
us285126
10-02-2015 02:03 PM
