Need Help with starting problem
Old 11-01-2002, 02:15 PM
3rd Gear
brooklyn44's Avatar
Have had a problem with car not starting. After turning ignition key to position where all lights are lit on dashboard, I then turned key to start position and EVERYTHING goes dead. Nothing works. I lose the presets on the radio, the memory positions for seats and mirrors. It feels as though someone yanked the battery out of the car. I remove the key from the ignition, get out of the car, fool with the remote keyless entry to lock and unlock the car, get back in and voila, it starts. Have to then put in the code for the radio, reset stations, and reset memory position for seats and mirrors. This all happened once, about two months ago and the dealer was "unable to duplicate situation". This week the same thing happened five times. My CL, type S is at the dealer now, but when I left I heard the dreaded words, "I've never seen anything like this before". I own an'01 CL, type S and an '02 TL type S and my wife and I love them both. First time ever posting to anything.
Thank you.
Old 11-01-2002, 02:45 PM
CO-CL-S's Avatar
Since this is the second time it has happened, I would suspect they may replace your ignition switch?
Old 11-01-2002, 03:21 PM
3rd Gear
brooklyn44's Avatar
Thanks, I'll let the dealer know.
Old 11-01-2002, 06:30 PM
BC
nearsighted visionary
BC's Avatar
Should probably check battery cable connection. When tracing electrical probs, do the easy stuff first. Good luck.
Old 11-02-2002, 10:28 AM
3rd Gear
brooklyn44's Avatar
Thanks for your help. The dealer found a very loose positive battery cable. Duh? You were right on the money.
Powder Monkey
2G CL Problems & Fixes
09-09-2018 12:55 AM
obert
12-14-2015 11:36 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
jordanboi
09-05-2015 01:33 AM
NSolace
09-03-2015 08:02 PM
Quick Reply: Need Help with starting problem
