My CLS6 Supercharged Build
Old 08-04-2016, 04:50 PM
  #81
coopcoop30's Avatar
Finally done installing everything that I had minus the front lip. Still haven't worked that one out but in time I will.
Old 08-04-2016, 04:51 PM
  #82
coopcoop30's Avatar
teh CL (08-04-2016)
Old 08-05-2016, 07:21 AM
  #83
3.5 psi
gnuts's Avatar
Looking good!
Old 08-06-2016, 07:20 AM
  #84
coopcoop30's Avatar
Thank you. I keep trying to justify getting rid of it and starting something else. But there isn't a car I would rather drive. Well the S2000 but that'll be next year.
Old 08-13-2016, 09:15 AM
  #85
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Great build, loving the car. What part of Ohio are you from?
Old 08-13-2016, 11:06 AM
  #86
coopcoop30's Avatar
Thank you.....I live in southeastern Ohio.......I would say 40 from Pittsburgh.
Old 08-13-2016, 11:29 AM
  #87
simione's Avatar
car looks AWESOME! Stock headlights look wayyyyy BETTER!
Old 08-13-2016, 12:56 PM
  #88
coopcoop30's Avatar
I agree man. I wish I would've never changed them in th first place. Although I still have the retrofits I think I'll keep them and try to retrofit a set of RLX jewel eyes in them......eventually.
Old 08-13-2016, 10:35 PM
  #89
03 tls nc's Avatar
Looks good! Really like the wheel!
Old 08-14-2016, 09:57 AM
  #90
coopcoop30's Avatar
I have the 18x8.5 A-spec TL wheels and the difference between the two is incredible. These are so much lighter and I can tell in corning and acceleration.
Old 09-29-2016, 12:00 AM
  #91
kali8686's Avatar
looking to put a sc in my 03 ... how does it pull ??? what clutch are you running ? and what the 1/4 time?
Old 09-29-2016, 10:08 AM
  #92
3.5 psi
gnuts's Avatar
is yours manual? I hope so. It's a blast to drive and the stock pulley (3.5psi) will be fine the stock clutch. I haven't seen many s/c times, but probably mid to low 13s depending on launch.
Old 09-30-2016, 07:29 PM
  #93
coopcoop30's Avatar
Never ran a 1/4 mile but I'm on the stock clutch and it pulls and pulls. 3rd gear is really impressive. You'll be more than satisfied. It's really changed the car when you step on it but retains the easy driving when you're not pushing it.
Old 09-30-2016, 07:32 PM
  #94
coopcoop30's Avatar
The launch is tricky. I guess once you get to the top of second and into third you're really moving a lot faster than a standard CL.
Old 10-25-2016, 05:17 PM
  #95
5th Gear
KeithbCLS6's Avatar
Originally Posted by coopcoop30
Love the car. Hope I have mine looking that good soon. You have put alot of work into it and I know it's worth it.
Old 04-24-2017, 07:24 PM
  #96
6th Gear
iBDKkiller's Avatar
What to know
Got my wheels mounted today. The wheels are bronze TSW Nurburgring 18x8.5. I didn't get a chance the weigh the wheels themselves. After the tires were mounted two weighed 38.4 pounds and two weighed 38.8 pounds.
Started rebuilding my calipers as well. The piston boots were all ripped so why not take a couples hours and rebuild them before I put them on the car.
just wanted to know if those caliper are the same as the 08-tl type s I know they have brambo brakes
Old 04-24-2017, 07:33 PM
  #97
6th Gear
iBDKkiller's Avatar
My cls6SC
Just wonder what else I can put in her I want to build the motor
Old 04-24-2017, 07:35 PM
  #98
6th Gear
iBDKkiller's Avatar
Finished painting the brake calipers today. The gold ACURA lettering is really close to the color of the wheels so I'm happy about that. They came out decently. I probably should've taken more time with prep but they are good enough that I won't do them over.
are those the same caliper from the 08-TL
Old 04-24-2017, 07:39 PM
  #99
3.5 psi
gnuts's Avatar
What psi are you running?
I think he has the RL calipers which are different from the TL brembos.
Old 04-25-2017, 08:01 AM
  #100
6th Gear
iBDKkiller's Avatar
I'm only running about 4_5 lbs. and if those are the RL calipers would I still need the brackets to install them
Old 04-25-2017, 08:19 AM
  #101
3.5 psi
gnuts's Avatar
yes you need the bracket for the RL calipers which you can get from a few places. The 3rd gen TL brembos don't fit and they don't make a bracket for those. (unless you swap knuckles and other things) Also the RL calipers require new pads and rotors and looking at your rims - I'm guessing they're 18x7.5 +48 - they won't clear. I don't even think they're clear my rpf1 and they're 18x8 +35.
You don't need to build the motor. Just up the boost, add some cooling and tune it if you want more power.
iBDKkiller (04-26-2017)
Old 04-25-2017, 10:57 PM
  #102
6th Gear
iBDKkiller's Avatar
Ok I'll start looking for the brembo conversation kit
I am already waiting on my high boost pulley and adding my front mount intercooler I'm also thinking about upgrade fuel injectors to 550cc and swapping out my my intake manifold with a 3.7L intake.then off to a tuning
Old 04-26-2017, 08:10 AM
  #103
3.5 psi
gnuts's Avatar
the brembo kit is discontinued I believe. any BBK you'll need spacers for your particular rims by the looks of it. The RL option is the best looking and cheapest option. You could also use the Legend calipers or NSX calipers which are not a BBK but they are 2 piston calipers and they will clear any rims.
What are you going to tune with?
Old 04-26-2017, 08:35 PM
  #104
6th Gear
iBDKkiller's Avatar
I have a Greddy E-manage ecm haven't installed it yet cuz I'm waiting on the HBP.
Old 04-28-2017, 09:03 PM
  #105
coopcoop30's Avatar
Yeah they are the RL calipers. I got the adapter to install the brakes from fastbrakes.com. Gnuts told you already but your rims have to be a certain offset to fir the calipers. I think the offset depends on the rims though so it's tricky.
What do you plan on doing with the E-manage?
AfilthyHOBO
01-29-2020 04:12 AM
abovetheclouds
ILX
07-18-2016 01:51 PM
Quick Reply: My CLS6 Supercharged Build
