Lookin into buying an 02 Type S that needs a transmission...
Old 09-01-2017, 02:39 AM
bks
bks's Avatar
Lookin into buying an 02 CL-S that needs a transmission, I have an 02 Base, can I swap transmissions from the base to the Type S and have everything function correctly?
Old 09-01-2017, 04:49 AM
lateralus's Avatar
better to do the av6 trans swap.. do a search for it quite popular with the tl fellas.. then you'll have two good cars.. instead of butchering one for another..
Old 09-01-2017, 04:52 AM
bks
bks's Avatar
just curious if the base and type s trans from the same year are interchangeable since i already have the transmission...
I'm not butchering two cars to make one, because the donor CL was sideswiped and totalled... so im using the engine in an 03 TL and plan to use the trans in this other CLS...
Old 09-01-2017, 03:41 PM
Unregistered Member
Karanx7's Avatar
Seems like a lot of work to still have a shitty transmission.
Old 09-02-2017, 01:01 AM
bks
bks's Avatar
yea, 6-5 hrs to swap trans on my lift.
i guess no one really knows the answer.
Old 09-02-2017, 03:59 AM
01acls's Avatar
Yes you can but the torque converter should follow the motor not the trans.
Old 09-02-2017, 04:05 AM
bks
bks's Avatar
ok cool, thanks. im not sure if reusing the old TC would be a good idea due to the original trans in the car failing. if i used the base model TC, what problems would I have?
Old 09-02-2017, 04:10 AM
01acls's Avatar
To enhance the durability of the 2g trans use 2 doses of XADO AT EX120. It will reduce friction, rehab the trans back towards nomimnal tolerance on metal parts, and protect the trans from additional wear.
Old 09-02-2017, 04:17 AM
01acls's Avatar
While you have the trans out change the external ATF filter. Check the filters in Pressure Solenoids A/B & C. Likewise, check the screens at the ends of all the other Shift Solenoids & Gear Switches.
Old 09-02-2017, 04:26 AM
01acls's Avatar
The S torque converter will fit both cars but my guess is you may have lock up issues or not. But to be safe I would use the correct one for the motor.
​​​​​​Torque converters are relatively inexpensive so buy a new one don't reuse the old one.
Old 09-02-2017, 04:47 AM
bks
bks's Avatar
Ok cool. thanks for the tips too.
Im lookin at TC's on rockauto, they dont differentiate between Type S and Base/Premium, but they do have different part numbers on honda/acura online parts catalogs (acuraoemparts.com)
Old 09-02-2017, 01:49 PM
01acls's Avatar
Correction
There are no filters on the Gear Switches so no need to check those.
Old 09-20-2017, 02:43 AM
bks
bks's Avatar
I ended up scrapping the car, had a lot of interest in parts off it. the cat scrapped for $189
