I need help, guys!! Engine does NOT turn!
Hi, guys. I need tons of help!!
First of all, my 2001 CL-S was having a radiator problem and leaked lots of coolant. Found the leak in the tube, got it fixed. Since that got fixed, I thought my raging temperture gauge will go down, and it did...untill some fool hit the right front side of my car, damaging the right corner of bumper, headlight, and the foglamp/light. Then the temperture started going way above the red again. After this incident, the coolant drains very weird. Sometimes I look and there's nothing. Sometimes I look and there's coolant overflowing in the reserve tank, but the other tank is dry. Whenever I refill, the temperture stays okay. While having these problems, my CL does the same weird thing alot of people are experiencing; VSA light comes on, and the malfunction indicator light came on at the same time VSA started popping out. And I do the same, turning the car off and on, then VSA light would go away. The malfunction indicator light dissapeared once or twice since then but it's normally on.
Three days ago, I just went to the local grocery store and came home, no problem. It started just fine, drove smoothly. The very next day, ready to go to work, And the Car wont start, it just cranks but wont turn, couple of times it started to turn but just fell out flat in 1-2secs. Theres No Clicking sound so i know its not the starter?? Any Ideas any help on where my coolant is going cause there is no leaks but i have to refill it at least 1 time every 2 weeks. And ideas on why it wont start...?? SOrry for the long post any help would be great thanks people!
yeah, def. check your oil. if you blew a headgasket, all of your coolant might have drained into the oil. possibly causing a catastrophe. your oil will look milky if there is water in it.
Loose Cannon
Originally Posted by Zippee
Sounds like you blew a head gasket when it over heated and the water is leaking into the oil pan.
sounds about right, unfortunately....
Thanks for all of your responses, guys! The thing is, that I have never seen any smoke coming out of the hood or the exhaust. When it started over heating in the begining, I saw a little bit of smoke from the hood but it was just kinda like the "steam" from a kettle. Not like a steam boat at all. I'm going to check the oil stick and the oil pan and see if it's milkey, but the last time I checked, it was just separating, (the oil part and the coolant part) but was not milkey.
Do you guys think all these things (over heating, the mulfanction indicator light, and the engine not turning) are related to one another? Like one cause the other and as a result the car is dead?
At first, I was thinking the oxygen sensor...could it be that sending wrong information to all the parts in the engine causing everything to mulfanction?
I'm so tired of catching the cab everywhere...
I know fixing the head gasket is a major hole in the wallet....I wish I can just wake up from this nightmare...and my CL is still riding smoothly...
Originally Posted by o1s
spun bearing could cause the engine to seize. water can def. do a little of that damage.
Loose Cannon
DUDE, i like how you say " the last time i checked it was just seperating the oil part and the coolant part."
What the hell do you mean by this?
So could a cylinder full of water which is very likely if the head gasket is leaking.
well he said that he didn't notice it burning anything when he drove it.
Much more likely than a "spun" bearing.
Moderator Alumnus
Spun bearing, blown gasket, dead cylinder, cracked rod, or cracked crank. Either way it is pretty costly tearing into the engine. Sometimes people just buy a new short block to over come the overspending tearing into the broke engine. Sorry to hear the issue man. If it was the Oxy sensor you'd know, a dumby light would come on and your car would still crank. If it was the cat converter your check engine light would be blinking, yet your car would still crank.
Thanks guys for all the opinions. Well, I'm a "she" not a "he" so please excuse my amature terminology. Okay, since then, I had my car towed to my uncle's factory because he has his own trusted mechanic. I've been waiting for his diagnosis and come to find out, my uncle has been in Korea for business and won't be back until this weekend. Sorry for the slow process but if you're still interested in helping me I'd appreciate it...and I will definetely update you on how my poor CL is!
I'm here in spirit...
Oh, by the way, Icsyle, I meant to say that the oil and something else was on top of each other like when you put water and oil...You know how it gets separated? And you can see the layers? Yeah, that's what I meant, dude.
HeloDown
09-08-2015 06:51 PM
