how much power can the cl-s OEM clutch hold?
Old 06-12-2011, 07:38 PM
e r y k's Avatar
heyya
I remember coming across this in a thread a while back, but I cant seem to find it.
I think there were a few folks running CT S/C on their j32's with no issues on the OEM clutch, IIRC?
does anyone remember the thread?
thanks!
Old 06-12-2011, 08:40 PM
I Wanna Beer
TheWeez's Avatar
Stock clutch is more than enough for holding the power the CT supercharger makes even with the high boost pulley.
Old 06-12-2011, 08:44 PM
Lives in Boost
CL-Future's Avatar
Not sure of the thread but the OEM clutch has been OK for me. Definitely slips sometimes when I get on it hard during 3rd to 4th gear shifts and at times during 1st to 2nd but not often. I tend to have to slow down my 3rd to 4th gear shifts during spirited driving but you can still shift pretty quickly in doing so.
Still want to get an aftermarket clutch though. I think Rajca has the P2R disc and that's been holding up well but I think he gets slippage from time to time as well.
Old 06-12-2011, 08:57 PM
JBlueCLS6's Avatar
I disagree, my car experienced a lot of slippage from a dig and even moving at a decent rate of speed (30-40 mph/3rd & 4th gear).
This was with a high boost pulley, I can't say I slipped NA.
Old 06-12-2011, 09:04 PM
e r y k's Avatar
i dont know if its a weather related issue, but its in the high 90s here.
its really weird though, my clutch will slip one day, and it wont slip the next. im wondering if the friction material gets "rehardened" when it cools and it is good until it wears down again.
im also debating removing my check valve in my slave cylinder, but not sure if it will help.
Old 06-12-2011, 11:47 PM
I Drive Like A Dick 8≈
Nersh7's Avatar
Do the check valve removal it will make a difference.
I find that I get bad clutch slippage on my oem clutch after driving it for a few hours straight.
I recently did a little trip down to montana and did about 150 kph most of the way and anytime I shifted it was really bad, I had to be super careful to avoid it.
Old 06-16-2011, 10:24 PM
Rejckt's Avatar
stock clutch didn't hold for my car with hbp.
Old 06-17-2011, 10:09 AM
OG 3.x^7 rawr
SPoolinspOON's Avatar
oem clutch held up to my build @ 300whp/280tq with 35-40k miles and was still holding.....
Old 06-17-2011, 10:30 AM
I got the Shifts
phee's Avatar
check for a bad rear main seal.
Old 06-17-2011, 10:31 AM
I got the Shifts
phee's Avatar
i must chime in and say that ERYK cannot drive a stick...
Old 06-17-2011, 12:19 PM
reese8789's Avatar
My stock clutch is holding good with aasco flywheel, no soft lines or dampers.
Old 06-17-2011, 07:38 PM
Blown is Best
Allout's Avatar
No problems with holding on mine.
Old 06-18-2011, 01:41 PM
e r y k's Avatar
it was the check valve. i removed it yesterday, zero slipping
mugen_kid
11-13-2015 10:38 PM
lland
10-04-2015 04:47 PM
09-14-2015 03:16 PM
heyitsvic
09-04-2015 09:38 AM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: how much power can the cl-s OEM clutch hold?
