Horn wiring question
Old 08-22-2006, 04:28 PM
fuzzy02CLS's Avatar
I have something I need to tie into the cars horn. I have a wire I need to splice into the horn. Single wire. Question is where along the line? Should I splice the horn circuit at the steering wheel or the horn. Our cars have 2 horns a high & low. Should I split the single wire into 2 wires & then splice into both horns?
What I need is to activate the device when I press the horn pad.
Old 08-22-2006, 05:13 PM
Zippee's Avatar
Don't know about Acura but on a lot of cars the horn is aways "hot" and the button completes the ground circuit. You should be able to tell with a volt meter.
Old 08-22-2006, 08:15 PM
fuzzy02CLS's Avatar
Yeah I know the wiring & which wires to use, but the CLS has 2 horns. Other cars I had only had 1, & the instructions only reference a 1 horn system. So I'm a bit confused as to what side I should splice into.
Old 08-22-2006, 10:32 PM
CLeanest in its CLass
CLean 3.0's Avatar
you can tap in at the horn. if you dont want the other horn to sound just disconnect it. and the wiring at the horn isnt "hot" it powers up from the horn relay when you ground the relay at the steering wheel switch. then the horn is grounded at its mounting plate.
Old 02-16-2022, 10:38 AM
4th Gear
Fanatic44's Avatar
06 tl horn
I have an aftermarket steering wheel and hub on my car 2006 tl i want to wire the horn up but unsure what wire is the horn wire color i dont want to cut and splice the wrong wire if someone knows witch color it is that would be appreciated
Old 02-16-2022, 12:38 PM
Received 1,735 Likes on 1,391 Posts
You need to post your question in the forum specific to the generation of your car; 3rd generation TL.
This is the 2G CL forum.
Or you can download one of the PDF service manuals, on the thread below, and look-up the information you seek.
2006 TL Searchable PDF Service Manual - AcuraZine - Acura Enthusiast Community
BoricuaTL
04-08-2016 01:08 PM
Type S Zero
02-17-2016 02:37 PM
VA2000TL
10-02-2015 08:26 AM
datadr
09-12-2015 09:12 PM
alan_rich
09-07-2015 11:08 PM
Quick Reply: Horn wiring question
