Honda Acura brake fluid shelf life
Does anyone know what is the shelf life of Honda Acura type 3 brake fluid.
1. For a closed plastic container, where the cap and seal have never been opened.
2. For a container that has been opened before.
Thank you
Thank you
justnspace (11-09-2016)
Brake fluid
The brake fluid containers are new. I believe it is approximately four years old. The containers seemed to be sucked in and in a crumpled form. thanks.
I Wanna Beer
Plastic still leaks air with time even if sealed.
Brake fluid is cheap. I'd just go to the store and buy fresh stuff. And always throw the remainder away. Get a new one each time.
justnspace (11-14-2016)
When the container is sucked in that means it's still sealing. As the temperature drops so too will the pressure in the container. Hence the sucked in and crumpled container. If the container is leaking then the pressure inside the container will be same as atmosphere pressure. In that cast the the container wouldn't be disfigured. It will be normal... Roundish.
You're right it doesn't expire exactly, but it does have a shelf life of 5 years (I've heard up to 10 but why risk it). Since the "date" stamp has an "SLW" next to it, I wonder if that stands for "shelf life something" which might mean this bottle is past its shelf life and shouldn't be used.
Eurotrash
If it's genuine Honda BF and came from a sealed bottle I'd use 10 year old BF. But you should ask the seller what that number really means if you're worried.
JJones91
2G RL Photograph Gallery
104
11-29-2016 10:45 AM
prepreludesh
05-14-2016 02:44 PM
