Honda Accord V6 6 Speed Transmission Question
Right now I have a 2003 CL 6 speed manual transmission. It needs to be rebuilt. Don't want to rebuild it yet out of cash so I found some cheap accord 6 speed transmissions at the junk but before I buy it. I read in the past that the accord shifters are reversed because its in the opposite position or somehting? or are the shifters the same and plug and play with the CL linkage. I might of been reading about the TL 6 speed transmission. So to sum it up will the accord transmission work with the CL shift linkage.
Latent car nut
Received 2,005 Likes
It is my understanding the Accord V6 6-Speed manuals and the CL/TL 6-Speed manuals are interchangeable from the perspective of bolting in and connecting the linkages. That said, the Accord V6 6-Speed manuals do NOT have the Limited Slip Differential which is built into the CL/TL transmissions.
Regarding the whole reversed shifter thing; that only applies only to the 4-Cylinder manual transmissions from the Gen 6 and earlier Accords.
I found the site I was looking at. its the 6 speed obsession thread. On the main page it says you can use an accord or 4G TL transmission but have to weld a stud. They say they;ll get into that later but theres nothing else on the page.
OP, what model year's are you referring to when talking about the Accord 6-speed transmissions, just curious?
Cheap + Accord 6 speed transmission = 03-07 Accord 100%.
I've seen them for as low as $150..
As for what your trying to do, your gonna lose LSD & as mentioned above, the Accord trans doesn't have the flyheel sensor.
Revival time. Is there a happy update for this? Is it possible to correct the Accord's lack of LSD and sensor? Basically, can one make it operate (almost) exactly like the CL-S' original trans? Apologies if those are silly questions, I am not at all familiar with transmissions, let alone swaps and all their intricacies.
Latent car nut
A very quick analysis, based on the info provided by teh CL above, of the final drive gear; differential bearings; countershaft and main shaft between the 2003 V6 Accord manual transmission and the 2003 CLS6 reveals that they both share the same part #'s.
So, theoretically, if you bought the CLS6 LSD on the link below:
https://acurazine.com/forums/market/968666
Purchased or already have the CLS6 Clutch housing case #1 on the link below:
https://www.oemacuraparts.com/auto-p...h-housing-scat
Purchase or already have the tranny side crank sensor #13 on the link below:
https://www.oemacuraparts.com/auto-p...h-release-scat
And if you have a capable Acura/Honda manual transmission mechanic who can tear both transmissions apart and reassemble the Accord 6-speed with the CLS6 parts above you should have an 03 honda Accord V6 manual transmission with LSD.
horseshoez (07-09-2018)
Latent car nut
zeta (07-09-2018)
In the interest of clarification and making this thread as accurate as possible, .
If your intent is to just get the CLS6 LSD benefits in your Honda Accord 6-speed car, then you would not 'swap' the Accord Shift Lever, #3 on the link below, or CLS6 clutch case to keep it compatable with the Accord shift linkage.
https://www.oemacuraparts.com/auto-p...ft-arm-v6-scat
If your intent was to purchase a cheap Honda Accord '03-'07 6-speed to replace a 'blown' '03 CLS6 scarce/expensive transmission with the desire to have the benefits of the LSD, along with the CLS6 clutch case you would either need to 'swap' the CLS6 Shift Lever, #3 on the link below, or weld a pin onto the Accord Shift Lever to make it compatable with the CLS6 shift linkage. The 'pin' locations of the Shift Levers are different between the two makes/models, as the links show.
https://www.oemacuraparts.com/auto-p...ift-lever-scat
AyyCee
10-07-2017 10:17 PM
07-20-2009 05:00 PM
Speed_Racer
12-04-2005 08:22 PM
PLuGiNn
06-30-2005 08:35 AM
hafmanhafblazin
08-09-2003 05:29 AM
