Going to change the timing belt on the CL-S. What parts do I need?
So far I've gathered that I'll need to replace the:
1. timing belt (I'll need two right?)
2. water pump
3. tensioner pulley
4. coolant
What else do I need?
2. water pump
3. tensioner pulley
4. coolant
I'm a Vagiterian.
According to THIS THREAD here's what you'll need. I'd suggest reading the thread, as well.
$96.60- New water pump.
$29.44- Timing belt.
$53.20- Tensioner pulley.
$43.63- Idler pulley.
$11.94- Alternator belt.
$10.99- Power steering belt.
$12.60- Power steering fluid.
$21.75- Spark plugs. NGK PZFR6E-11
$280.70- Total
I'd also suggest getting a supercharger, too.
$280.70- Total
I did mine about a year ago and I found out you need a special tool to get the crank shaft pulley off. I couldn't get around it. You may be able to borrow one or rent one. i couldn't
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
