Getting to the defroster vents without removing the dash?
Old 03-29-2012, 05:01 AM
RooEng's Avatar
I'm trying to chase down a rattle and it's sounds like it's coming from the defroster vents near the middle of the dash. Do I have to remove the whole dash or will they come up from the top? I took the instrument panel off and can't get to them. I can't even see them.
Old 03-29-2012, 06:20 AM
Lone Wolf
brian6speed's Avatar
I am having a similar situation, but for me it is a broken temp sensor that is lodged in that middle little hole. I might have to remove the whole dash to get it out.
You can pry those vents out from the top, but chances are you will distort how the dash will fit/look and it will never go back.
Old 03-30-2012, 04:00 AM
vaymoon's Avatar
They are clips, becareful they are really brittle. If you like I can show you pictures on how to take off the dash.
As for the temp sensor its a clip too. Should be very easy to pry off.
Old 03-30-2012, 10:55 AM
Lone Wolf
Those are not even the right vents you posted.
The top of my temp sensor was broken off by a shop and they shoved the other part of sensor back in the hole and put the broken piece on top. It is not easy to remove in this case.
Old 03-30-2012, 04:38 PM
RooEng's Avatar
[QUOTE=vaymoon;13664682]They are clips, becareful they are really brittle. If you like I can show you pictures on how to take off the dash.
Pictures would be great. It'll give me an idea of what I"m up against.
12vancover
10-16-2015 12:04 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Skirmich
10-01-2015 12:59 PM
2Quik
09-23-2015 01:03 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: Getting to the defroster vents without removing the dash?
