Fuse to passenger seat keeps blowing
I took the fuse out that goes to the forward-backward movement of the passenger seat. Now when I try to put it back in, it blows everytime right as I insert it.
I was going to use this fuse spot for power to a small piece of electronics, but changed my mind and decided to use the fuses on the other side of the car. But I don't have anything else plugged in that fuse block.
Any ideas on what I might do to fix this?
Nope... used 20 amp fuse like is supposed to be there.
This one has me quite confused. I'm afraid that perhaps the motor has a short in it.
I should be able to take the fuse out and then put it back in without hurting anything.
I've even tried unhooking the battery, putting the fuse in, letting the car sit for 5 minutes and then hooking the battery back up. Still popped the fuse.
Any other suggestions on what I might try?
SUPRMN84
10-07-2015 09:46 PM
